This document is for the LaserJet Pro P1102, P1102s, P1102w, P1106, P1108, P1109, and P1109w printers.
- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
HP LaserJet Pro Printers - Setting Up Printer Hardware
This document includes the following steps to set up the printer:
Check the contents of the box
Remove packing tape
Prepare the print cartridge
Load plain paper
Turn on power
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Remove the printer from the box, and then check the contents of the box.
Step 2: Remove packing tape
Remove all packing tape from the printer.
Step 3: Prepare the print cartridge
Open the print cartridge door.Figure : Open the print cartridge door
Remove the print cartridge packaging.Figure : Remove the print cartridge packaging
Remove the print cartridge from the printer.Figure : Remove the print cartridge
Attention :
To prevent damage to the print cartridge, hold the print cartridge at each end. -
Remove the packaging from inside the printer.Figure : Remove the packaging from inside the printer.
Remove the orange clip from the end of the print cartridge.Figure : Remove the orange clip from the print cartridge
Gently rock the print cartridge back and forth to distribute the toner evenly.Figure : Rock the print cartridge
Bend the tab on the left side of the print cartridge until the tab breaks loose, and then pull the tab to remove all the sealing tape from the print cartridge.Figure : Remove the sealing tape
Attention :
If toner gets on your clothing, wipe it off with a dry cloth and wash the clothing in cold water. Hot water sets toner into the fabric. -
Insert the print cartridge, and then close the print cartridge door.Figure : Insert the print cartridge and close the door
Step 4: Load plain paper
To load plain paper in the main input tray, follow these steps.
Slide the paper length and width guides to their outermost positions.Figure : Slide out paper guides
Load plain paper in the main input tray with the top forward and the print side up.Figure : Load paper
Slide the paper guides inward so that they rest against the stack of paper.
Remarque :
To prevent jams and skewing, always adjust the side and front paper guides.Figure : Adjust the paper guides
Step 5: Turn on power
Connect the power cord to the back of the printer.Figure : Connect the power cord
Plug the power cord into an electrical outlet.
Press the Power button to turn on the printer.Figure : Turn on the power
Remarque :
A blank page might print when you turn on the printer for the first time.
Getting started with ePrint
Now you can stay connected and productive on the go with ePrint. ePrint lets you print directly to your ePrint-enabled HP printer using a smartphone, notebook, or other mobile device. For additional information related to setting up and using ePrint, click the link provided.
HP ePrint
Options de support supplémentaires
- ${title}
Chargement...
- ${title}
Chargement...
- ${title}
Chargement...
Pays/région :
France
- ${title}
Chargement...
hp-hero-support-search
- ${title}
Chargement...
