Chargement...
Chargement...
Chargement...
    Avez-vous besoin d'aide avec Windows 11 ?
    Vérifiez les informations sur la compatibilité, la mise à niveau et les correctifs disponibles auprès de HP et de Microsoft. Centre d'assistance Windows 11
    Problèmes de son ou de l’audio ? Essayez notre outil automatisé, HP Audio check!
  • Avis
Chargement...
HP LaserJet P1505 and P1505n Printers - Setting Up the LaserJet (Hardware)
  • Unpack the printer
  • Install the print cartridge
  • Connect the power cord
  • Turn on power
  • Load plain paper
Setting up the printer
Follow these steps in order.
The following video demonstrates how to remove the packing materials from your product. The product shown in the video is the HP LaserJet P1505n. The outside of the product might look different, but the steps are similar for your product.
Step one: Unpack the printer
Remove all the orange shipping tape and packaging material from the product.
Figure : Unpack the product
Illustration:  Unpack the product
Step three: Install the print cartridge
Follow these steps to install a cartridge.
  1. Openthe print cartridge door.
    Figure : Open the print cartridge door
    Illustration: Open the print cartridge door
  2. Remove the new print cartridge fromthe packaging.
      Attention :
    To prevent damage to the print cartridge, hold the printcartridge at each end.
  3. Pull the tab until all the tape is removedfrom the cartridge. Put the tab in the print cartridge box to return for recycling.
    Figure : Remove the sealing tape
    Illustration: Remove the sealing tape
  4. Gently rock the print cartridge fromfront to back to distribute the toner evenly inside the print cartridge.
    Figure : Rock the print cartridge
    Illustration: Rock the print cartridge
  5. Insert the print cartridge, and then close the print cartridge door.
    Figure : Insert the print cartridge
    Illustration: Insert the print cartridge
      Attention :
    If toner gets on your clothing, wipe it off with a dry clothand wash the clothing in cold water. Hot water setstoner into the fabric.
Step four: Connect the power cord
  1. Connect the power cord to the back of the product.
    Figure : Connect the power cord
    Illustration:  Connect the power cord
  2. Plug the power cord into an electrical outlet.
Step five: Turn on power
Press the Power switch to turn on the product.
Figure : Turn on the product
Turn on the product
Step six: Load plain paper
  1. Slide the paper width and length guides to their outermost positions.
    Figure : Slide out the paper guides
  2. Place the stack of paper in the tray, and then make sure that it is flat at all four corners.
  3. Slide the paper guides inward so that they rest against the stack of paper.
    Figure : Adjust the paper guides
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
