Chargement...
Chargement...
Chargement...
Chargement...
HP Photosmart A826, A827, and A828 Printers - Installing the Print Cartridge
This document contains instructions for installing the print cartridge.
Install the print cartridge
  1. Open the output tray.
  2. Open the print cartridge door.
    Figure : Opening the print cartridge door
  3. Open the print cartridge package. Pull the pink tab to remove the clear tape from the print cartridge.
    Figure : Removing the tape from the print cartridge
    Remarque :
    Do not touch or remove the ink nozzles or the copper-colored contacts on the print cartridge!
  4. Insert the print cartridge into the print cartridge cradle with the label facing up and the copper-colored contacts facing the inside the printer.
    Figure : Inserting the print cartridge
  5. Push the print cartridge into the cradle until it snaps into place.
  6. Close the print cartridge door and touch OK.
Align print cartridge
The first time you insert a HP 110 Tri-color Inkjet print cartridge, the printer aligns it automatically. However, if colors in printouts are misaligned, or if the alignment page does not print correctly when you insert a new print cartridge, use the following procedure to align the print cartridge.
Follow the instructions below to print an alignment page:
  1. Verify that 10 x 15 cm (4 x 6) inch paper is loaded in the input tray.
  2. Touch OK and an alignment page should print. If the alignment page does not begin printing follow the steps below.
    1. Touch the Menu icon on the quick touch frame.
    2. Touch Cartridge.
    3. Touch Align Cartridge.
    4. Touch OK. The test page prints.
Figure : HP Photosmart A620 series alignment page
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
