Chargement...
Chargement...
Chargement...
Chargement...
HP Photosmart 325, 335, 375, and 385 - Installing Print Cartridges
  1. Open the print cartridge access door, then wait until the print cartridge carriage is idle and silent.
    Figure : Opening the print cartridge access door
  2. Press down on the end of the cartridge to release it.
    Figure : Releasing cartridge
  3. If you are installing a new print cartridge, remove the protective tape.
    Figure : Removing the protective tape
  4. Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
    Remarque :
    Avoid touching the nozzles or contacts!
    1. Contacts
    2. Nozzles
    Figure : Installing the cartridge
  5. Press the cartridge into the carriage until it snaps into place.
  6. Close the print cartridge access door.
Chargement...
Chargement...
Chargement...
Pays/région : Flag France
Chargement...
