Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
HP Laser Printers - Wireless Printer Setup
This document is for HP Laser 100, Laser 130 MFP, Color Laser 150, and Color Laser 170 MFPs.
Use a USB cable or the direct wireless connection method to establish a wireless connection between your printer and network.
Step 1: Prepare for installation
Prepare for installation before setting up the printer on a wireless network.
  1. To use your printer on a wireless network, you need the following items:
    • A compatible computer or mobile device connected to your wireless network
    • Internet access
    • A USB cable (might be required during installation)
  2. Make sure the router is turned on.
  3. If you are connecting your printer using your computer or mobile device, make sure it is connected to your wireless network.
  4. Place the printer close to the computer or mobile device and within range of the router.
  5. If you plan on printing from a mobile device, first setup the printer from a computer using the steps in this document. After the printer has been set up, download HP Smart app to your mobile device and add your printer.
Step 2: Restore network defaults
Use buttons on the control panel to put your printer in wireless setup mode. If you are setting up your printer for the first time, skip to the next step.
  • HP Laser 100, Color Laser 150: Press and hold the Wireless button for at least 20 seconds until the Attention and Power LEDs blink together.
  • HP Laser MFP 130, Color Laser MFP 170: Press the Menu button , press the Right arrow until you see Network, press OK, press the Right arrow until you see Wi-Fi, press OK, select Wi-Fi Default, and then press OK.
Step 3: Connect the printer to your wireless network
Set up the printer on a wireless network using the USB cable, a direct wireless connection method, Wi-Fi Direct, or the Wi-Fi Protected Setup (WPS) method.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
