This document is for HP ENVY Photo 6220, 6230, 6232, 6234, 6252, 6255, 7120, 7130, 7134, 7155, 7158, 7164, 7820, 7830, 7855, 7858, and 7864 All-in-One printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then download and install the printer software.
huomautus:If you are looking for the print driver or mobile app, go to the HP printer setup service at 123.hp.com.
