Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
  • Palaute
Toiminnot
Ladataan...
HP OfficeJet Pro 8210 Printers - Replacing Ink Cartridges
This document is for the HP OfficeJet Pro 8210, 8216, and 8218 printers.
This document contains steps for replacing the ink cartridges.
Replace the ink cartridges
Replace any low or empty ink cartridges.
  1. Turn on the printer.
  2. Open the ink cartridge access door.
    Image: Lift the ink cartridge cover
  3. Wait until the carriage stops moving before you continue.
  4. Push in on the front of the ink cartridge to release it, and then pull the ink cartridge toward you to remove it.
    Removing the ink cartridge
  5. Remove the replacement ink cartridge from its package.
  6. Carefully insert the new ink cartridge into its slot, and then push the ink cartridge forward until it snaps into place.
    Reinserting the ink cartridge
  7. Repeat these steps for the other ink cartridges.
  8. Make sure each ink cartridge is not sticking out farther than the other ink cartridges. If an ink cartridge is sticking out, push it until it snaps into place.
  9. Close the ink cartridge access door.
Review the list of frequently asked questions about replacing the ink cartridges.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
