This document is for HP DeskJet GT 5810, 5811, 5820, 5821, and 5822 All-in-One printers.
To set up a printer for the first time, remove the printer and packing materials from the box, connect the power cable, fill the ink tanks, install the printheads, load paper into the input tray, align the printheads, prime the ink system, and then install the printer software.
huomautus:If you are looking for the printer software, go to:
Printer software for HP DeskJet GT 5810 and 5811 printers: 123.hp.com/dj5810 Printer software for HP DeskJet GT 5820, 5821, and 5822 printers: 123.hp.com/dj5820
