Odota, yhteystietovaihtoehtoja haetaan
HP voi tunnistaa useimmat HP-tuotteet ja suositella mahdollisia ratkaisuja.
huomautus: If your printer does not have a scanner, skip to the next step.
huomautus: If you want to load legal-size paper, pull the front and rear of the tray to extend it. Kuva : Extending the paper input tray
huomautus: Do not overload the paper input tray. Make sure that the stack of paper fits within the tray and is no higher than the top of the guides.
huomautus: If you extended the paper input tray for legal-sized paper, the tray does not sit flush with the printer body when inserted.
varoitus: Do not connect a USB cable at this time. The printer prompts you to connect the USB during the software installation.
{{description}}
Sarjanumeron etsiminen Tuotenumeron etsiminen
Kirjaudu sisään, jos haluat jatkaa
