Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
  • Palaute
Toiminnot
Ladataan...
HP EliteBook 820 G1 Notebook PC Product Specifications
HP EliteBook 820 G1
Product features
Feature
Processor
  • 4th Generation Intel Core i7: 4600U with Intel HD Graphics 4400 (2.1 GHz, 4MB cache, 2 cores) Up to 3.3 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i5: 4300U with Intel HD Graphics 4400 (1.9 GHz, 3MB cache, 2 cores) Up to 2.9 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i5: 4200U with Intel HD Graphics 4400 (1.6 GHz, 3MB cache, 2 cores) Up to 2.6 GHz with Intel Turbo Boost Technology
  • 4th Generation Intel Core i3: 4010U with Intel HD Graphics 4400 (1.7 GHz, 3MB cache, 2 cores)
Chipset integrated with processor
Graphics
  • Integrated: Intel HD Graphics 4400
  • Discrete: AMD Radeon HD 8750M with 1GB dedicated DDR5 video memory
  • Internal:
    12.5-inch diagonal LED-backlit HD anti-glare SVA flat (1366 x 768)
    12.5-inch diagonal LED-backlit HD Premium anti-glare UWVA slim (1366 x 768)
    12.5 inch LED HD UWVA Touchscreen enabled for Webcam ultraslim (1366x768)
  • External:
    Up to 32-bit per pixel color depth
  • VGA:
    Port supports resolutions up to 1920 x 1200 external resolution at 75 Hz
Storage and drives
  • Hard drives:
    320/500GB 1TB 5400 rpm SATA II Hard Drive
    320/500GB 7200 rpm SATA II Hard Drive
    500GB 7200 rpm SED (Self Encrypting Drive) (Expected to be available in november 2013)
    500GB 5400 rpm FIPS SED (Self Encrypting Drive) (Expected to be available in november 2013)
  • Solid state drive:
    120GB M.2 (NGFF) Solid State Drive (Expected to be available in november 2013)
    128/180/240GB 2.5-inch olid State Drive
    256GB SED Solid State Drive (Expected to be available in november 2013)
Flash cache
32GB M.2 (NGFF)
Memory
  • Standard:
    DDR3L SDRAM (1600 MHz)
    Two SODIMM slots supporting dual-channel memory
    4GB and 8GB SODIMMs
  • Maximum:
    Upgradeable to 16384MB with optional 8192MB SODIMMs in slots 1 and 2
  • Dual-channel:
    Maximized dual-channel performance requires SODIMMs of the same size and speed in both memory slots
Audio/Multimedia
  • Audio:
    HD audio with DTS studio sound
    2 integrated stereo speakers
    Integrated dual-microphone array; located in the display
    Function keys for microphone mute, volume up, volume down
    Stereo headphone/line out
    Stereo microphone/line in
  • Webcam:
    Optional 720p HD webcam
Pointing devices
Touchpad with scroll zone, on/off button with LED indicator, two-way scroll, two pick buttons
Physical specifications
Dimensions (W x D x H)
31 x 21.53 x 2.1 cm (12.2 x 8.48 x 0.83 in)
Starting at 2.94 lb (1.33 kg) (weight will vary by configuration)
Display specifications
12.5-inch diagonal LED backlit HD (1366 x 768) anti-glare SVA flat
12.5-inch diagonal LED backlit HD (1366 x 768) Premium antiglare UWVA slim
Dimensions (W x H x D)
29.1 x18.14 x 0.36 cm (11.46 x 7.14 x 0.14 in)
29.1 x18.14 x 0.285 cm (11.46 x 7.14 x 0.112 in)
Active area
27.6615 x 15.552 cm (10.89 x 6.12 in)
27.559 x 15.494 cm (10.85 x 6.1 in)
270g (0.6 lb) (maximum)
220g (0.49 lb) (maximum)
Diagonal size
35.75 cm (12.5 in)
35.75 cm (12.5 in)
Surface treatment
Anti-glare
Anti-glare
Contrast ratio
300:1 (minimum)
500:1 (minimum)
Refresh rate
60 Hz
60 Hz
Brightness
200 nit (typical)
300 nit (typical)
Pixel resolution
  • Format: 1366 x 768 (HD)
  • Configuration: RGB stripe
Interface
eDP 1.2 (1 lane)
eDP 1.2 (1 lane)
LCD mode
TN
IPS/FFS/VA
PPI
125 ppi
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
UWVA 85/85/85/85 (Left/Right/Down/Up)
Storage and drive specifications
320GB 5400 rpm SATA Hard Drive
500GB 5400 rpm SATA Hard Drive
1 TB 5400 rpm SATA Hard Drive
500GB 5400 rpm SATA FIPS Hard Drive (Expected to be available in november 2013)
320GB 7200 rpm SATA Hard Drive
500 GB 7200 rpm SATA Hard Drive
500GB 7200 rpm SMART SATA II Self Encrypting Drive (Expected to be available in november 2013)
SATA 6 Gb/s 128 GB, 2.5 inch Solid State Drive
SATA 6 Gb/s 180 GB, 2.5 inch SATA Solid State Drive
SATA 6 Gb/s 240 GB, 2.5 inch Solid State Drive
SATA 6 Gb/s 256GB, 2.5 inch SATA SED Solid State Drive (Expected to be available in november 2013)
SATA 6Gb/s 120GB, 2242 M.2 Solid State Drive (Expected to be available in november 2013)
Drive weight
0.25 lbs (115 g)
0.22 lb (101 g)
0.254 lb (115 g)
0.25 lbs (95 g)
0.25 lbs (115 g)
0.25 lbs (115 g)
0.25 lbs (115 g)
73 g
78 g
78 g
73 g
Up to 10 g
Capacity
320GB
500GB
1TB
500GB
320GB
500GB
500GB
128GB
180GB
240GB
256GB
120GB
Height
9.5 mm (0.37 in)
9.5 mm ( 0.37 in)
9.5 mm ( 0.37 in)
7 mm ( 0.28 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
9.5 mm (0.37 in)
7 mm (0.276 in)
7 mm(0.276 in)
7 mm (0.276 in)
7 mm (0.276 in)
3.5 mm (0.138 in)
Width
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
70 mm (2.75 in)
70 mm ( 2.75 in)
63.5 mm ( 2.50 in)
70 mm (2.76 in)
70 mm (2.76 in)
2.76 in (70 mm)
70 mm (2.76 in)
22 mm (0.866 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
SATA 3 (6 Gb/s)
SATA Gen 3 (6 Gb/s)
SATA Gen 3 (6 Gb/s)
SATA 3 (6 Gb/s)
M.2 SATA Gen3 (6 Gb/s)
Transfer rate (Synchronous maximum)
300 MB/s (drive capability)
NA
NA
NA
NA
NA
Seek time (typical reads, including settling)
Single track : 1.5 ms
Average : 11 ms
Maximum : 22 ms
Single track : 3 ms
Average : 13 ms
Maximum : 24 ms
Single track : 3 ms
Average : 13 ms
Maximum : 24 ms
Average : 11 ms
Maximum : 22 ms
Average : 11 ms
Maximum : 22 ms
Average : 11 ms
Maximum : 22 ms
Single track : 1 ms
Average : 12 ms
Maximum : 20 ms
NA
NA
NA
NA
NA
Cache
NA
NA
NA
16MB
16MB
NA
16MB
NA
NA
NA
NA
NA
Rotational speed
7200 rpm
5400 rpm
5400 rpm
5400 rpm
7200 rpm
7200 rpm
7200 rpm
NA
NA
NA
NA
NA
Logical blocks
625,142,4488
976,773,168
1,953,525,168
976,773,168
625,142,448
976,773,168
976,773,168
250,069,680
351,651,888
468,862,128
500,118,192
234,441,648
Operating temperaturerere
0° to 60° C (32° to 140° F)
0° to 60° C ( 32° to 140° F)
0° to 70° C (32° to 158° F)
0° to 70° C ( 32° to 158° F)
Features
ATA Security
ATA security
ATA security
ATA security
ATA security
ATA security
ATA security
ATA security; ATA-8; SATA 3.0; DIPM; TRIM
ATA security; ATA-8, SATA 3.0; DIPM; TRIM SATA 6
ATA security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
performance
NA
NA
NA
NA
NA
NA
NA
  • Maximum sequential read: 415 MB/s
  • Maximum sequential write: 175 MB/s
  • Maximum sequential read: 550 MB/s
  • Maximum sequential write: 520 MB/s
  • Maximum sequential Read: 460 MB/s
  • Maximum sequential Write: 520 MB/s
  • Maximum sequential Read: 540 MB/s
Security specifications
HP fingerprint reader (optional)
Mobile voltage operation
3.0 V - 3.6 V
-10° - 75°C (14° - 167°F)
Current consumption image
36 mA peak
Low latency wait for finger
950 uA
Capture rate
3000 lines/sec
ESD resistance
IEC 61000-4-2 4B (±15 KV)
Detection matrix
  • 200 x 1 (plus another secondary line)
  • 508 dpi
  • 12 x 3 mm sensor area
Audio/Multimedia - DTS sound+ specifications
  • Implementation: IDT 92HD91
  • Function key volume controls: Volume up, volume down, and mute
  • Full duplex: Yes
  • Microphone in: Stereo
  • Headphone/Line out: Stereo
  • Integrated microphone: Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
  • Frequency response: 20 Hz - 20 kHz
  • Signal to noise ratio: >85 dB
  • Total harmonic distortion: 0.01%
  • Noise floor: -110 dB
  • Play/Record sampling rate(s): 8 kHz - 48kHz
  • DAC: 16, 20 or 24-bit
  • ADC: 16 or 20-bit
Integrated stereo speakers
  • Power rating: 2 W
  • Impedance: 4 Ohms
Software overview
Feature
Operating system (Preinstalled)
Windows 8 Pro 64
Windows 7 Professional (available through downgrade rights from Windows 8 Pro)
Windows 8 64
Windows 7 Professional 32
Windows 7 Professional 64
Windows 7 Home Premium 32
Windows 7 Home Premium 64
SUSE Linux
FreeDOS
Environmental specifications
Operating:
Temperature
0° to 35° C (32° to 95° F) (not writing optical)
5° to 35° C (41° to 95° F) (writing optical)
Relative humidity
10% to 90%, non-condensing
Shock
40 G, 2 ms, half-sine
Random vibration
0.75 grms
Altitude (unpressurized)
-15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating:
Temperature
-20° to 60° C (-4° to 140° F)
Relative humidity
38.7° C (5% to 95%, 101.6° F) maximum wet bulb temperature
Shock
200 G, 2 ms, half-sine
Random vibration
1.50 grms
-15.24 to 12,192 m (-50 to 40,000 ft)
Safety certifications
certifications
Planned industry standard certifications
  • UL: Yes
  • CSA: Yes
  • FCC Compliance: Yes
  • ENERGY STAR: Select models
  • EPEAT: Registered TBD in United States
  • ICES: Yes
  • Australia / NZ A-Tick Compliance: Yes
  • CCC: Yes
  • Japan VCCI Compliance: Yes
  • KC: Yes
  • BSMI: Yes
  • CE Marking Compliance: Yes
  • BNCI or BELUS: Yes
  • CIT: Yes
  • GOST: Yes
  • Saudi Arabian Compliance (ICCP):
  • SABS: Yes
  • UKRSERTCOMPUTER: Yes
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
