Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
  • Palaute
Toiminnot
Ladataan...
HP LaserJet Pro 200 color MFP M276 Printer Series - Replacing the Toner Cartridges
Replace the toner cartridges
  1. Open the front door.
    Kuva : Open the front door
  2. Pull out the toner cartridge drawer.
    Kuva : Open the toner cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull the toner cartridge straight up to remove it.
    Kuva : Remove the old toner cartridge
  4. Remove the new toner cartridge from the packaging.
    Kuva : Remove the new toner cartridge from the packaging
  5. Gently rock the toner cartridge from front to back to distribute the toner evenly inside the cartridge.
  6. Remove the plastic shield from the bottom of the new toner cartridge.
    Kuva : Remove the packing material
  7. Do not touch the imaging drum on the bottom of the toner cartridge. Fingerprints on the imaging drum can cause print-quality problems.
    Kuva : Do not touch the imaging drum
  8. Insert the new toner cartridge into the product.
    Kuva : Insert the new cartridge
  9. Pull the tab on the left side of the toner cartridge straight up to completely remove the sealing tape. Discard the sealing tape.
    Kuva : Remove the sealing tape
  10. Close the toner cartridge drawer.
    Kuva : Close the toner cartridge drawer
  11. Close the front door.
    Kuva : Close the front door
  12. Place the old toner cartridge and the plastic shield in the box for the new toner cartridge. Follow the recycling instructions that are included in the box.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
