Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
HP Photosmart C6200 All-in-One Series - Installing the Cartridges
This document contains information about installing the cartridges.
Video of replacing the cartridges
The following video demonstrates the steps for replacing the cartridges.
The following video demonstrates the steps explained on this page. The outside of the product might look different, but the steps are the same for your product.
If you have trouble viewing the video or to view the video in a different size, click here to play the video on YouTube.
Step one: Install the cartridges
huomautus:
The HP All-in-One must be on before you can insert the cartridges.
  1. After you press the On button, wait for the prompton the color graphics display before continuing.
  2. Open the access door by lifting it until it stops.
    Kuva : Opening the access door
  3. Squeeze the bottom of each latch to release it, andthen lift the latch.
      Kuva : Release latch
    1. Cartridge latch for the black ink cartridge
    2. Cartridge latches for the color ink cartridges
  4. Lift all six latches.
    Kuva : All latches lifted
  5. Match the color and pattern of the cartridge to thecolor and pattern on the ink carriage.
    1. Push the black ink cartridge into the first slot on theleft. Close the latch.
      Kuva : Black ink cartridge installation
    2. Repeat with each of the color ink cartridges.
      Kuva : Color ink cartridge installation
    3. Make sure each latch is secure.
      Kuva : All cartridges installed
      huomautus:
      Use only the cartridges that came withthe printer. The ink in these cartridges is speciallyformulated to mix with the ink in the print headassembly at first-time setup.
  6. Close the access door and follow the prompts on the color graphics display.
    Kuva : Closing the access door
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
