Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
  • Palaute
Toiminnot
Ladataan...
HP Photosmart C3100 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Connect the power cord and adapter
  • Turn on power
  • Load plain paper
  • Install the cartridges
Follow these steps in order.
  1. Remove all tape and packing material from around the product.
  2. Lower the paper tray and remove all tape and packing material.
    Kuva : Lower the paper tray
  3. Lower the cartridge door and remove all tape and packing material.
    Kuva : Lower the cartridge door
Step three: Connect the power cord and adapter
  1. Connect the power cord to the product and the power adapter.
    Kuva : Connect the power cord and adapter
  2. Connect the power cord to the electrical outlet.
Step four: Turn on power
  1. Press the Power button ().
    Kuva : Press the Power button
  2. Wait 30 seconds for the product to start up.
Step five: Load plain paper
  1. Pull out the tray extender.
    Kuva : Pull out the tray extender
  2. Load plain, unused, white paper.
    Kuva : Load plain, unused, white paper
Step six: Install the cartridges
  1. Open the cartridge door. Make sure that the carriage moves to the right. If it does not move to the right, turn the product off and then turn it on again.
    Kuva : Open the cartridge door
  2. Remove the tape from both cartridges.
    Kuva : Remove the tape
      varoitus:
    Do not touch the copper-colored contacts or re-tape the print cartridges.
    Kuva : Copper-colored contacts
  3. Hold the cartridges with the HP logo on top.
  4. Insert the tri-color cartridge in the left slot and the black cartridge in the right slot.
    Kuva : Carriage slots
    Kuva : Insert the tri-color cartridge in the left slot
  5. Push the cartridges in firmly until they snap into place.
    Kuva : Push the cartridge in firmly
    Kuva : Tri-color cartridge and black cartridge correctly installed
  6. Close the cartridge door.
    Kuva : Close the cartridge door
    huomautus:
    Make sure that unused, plain, white paper is loaded in the paper tray, then wait a few minutes while the cartridge alignment page prints. Alignment is complete after the page prints.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
