Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
HP Notebook PCs - Upgrade of Easy Access Button Software Fails When Using the Application Recovery CD in Windows XP
When attempting to upgrade the Easy Access Button (EAB) software using the Application Recovery CD (ARCD), the following error message is displayed in a popup box titled "Setup Compaq Software Error."
Compaq Easy Access Buttons failed
Solution
EAB software prior to version 3.0 rev B does not properly upgrade over already installed EAB software. To work around the issue above, use the following steps to uninstall "EAB" software in Add/Remove Programs.
Uninstall the Easy Access Button software
Uninstall the EAB software using the following steps:
  1. Click on Start.
  2. Click Control Panel.
  3. Then click Add or Remove Programs.
  4. Select the EAB program to delete and click the Remove button.
Install the latest EAB Software
Install the latest version (3.00 rev. B or later):
Softpaq Description
Download
Compaq Easy Access Buttons VERSION: 3.00 Rev B
huomautus:
A more recent version of this software may be available. Check for updated drivers and software for your computer at www.hp.com.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
