Make sure the printer is turned on. Press the Power button if it is not lit.Kuva : Press the Power button if it is not lit
- Open the printer cover, then wait until the print cartridge cradle is idle and silent.
- ${title}
Ladataan...
HP:n asiakastuki – tietämyskanta
- ${title}
Ladataan...
- ${title}
Ladataan...
- ${title}
Ladataan...
HP Deskjet 5740 Series Printers - Removing and Installing Print Cartridges
Step 1 - Open the printer
Kuva : Opening the printer
Step two: Remove old cartridges
Press down lightly on the end of each print cartridge to release it.
The tri-color print cartridge is on the left
The black or photo print cartridge is on the right
Kuva : Removing the tri-color cartridge -
Slide the cartridge out.
Step 3 - Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
Kuva : Insert a cartridge into a cartridge protector
Kuva : To remove, press down on the latch
Step 4 - Make sure the new cartridges are compatible
Step five: Install new cartridges
If you are installing a new print cartridge, remove the protective tape.
varoitus:
Do not attempt to remove the copper strip.-
Protective tape
Kuva : Removing the protective tapevaroitus:
After the tape is removed, do not touch the copper contacts or the ink nozzles.-
Contacts
Nozzles
Kuva : Contacts and nozzles -
Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
Cartridges marked with a triangle go into the left carriage slot.
Cartridges marked with a square or pentagon go into the right carriage slot.
Kuva : Sliding the cartridge into the carriage -
Push the print cartridge forward until it clicks into place.Kuva : Pushing the cartridge into place
Close the printer cover.
Muita tukivaihtoehtoja
- ${title}
Ladataan...
- ${title}
Ladataan...
- ${title}
Ladataan...
Maa/alue:
Suomi
- ${title}
Ladataan...
hp-hero-support-search
- ${title}
Ladataan...
