Toiminnot
Ladataan...
HP:n asiakastuki – tietämyskanta
Toiminnot
Ladataan...
Toiminnot
Ladataan...
  • Palaute
Toiminnot
Ladataan...
HP Photosmart 2600 and 2700 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the product and check the contents of the box
  • Attach the control-panel overlay (if not attached)
  • Load plain white paper
  • Connect the power cord and telephone cord
  • Turn the All-in-One on
  • Install the cartridges
  • Set the date and time
Follow these steps in order.
Step one: Unpack the product and check the contents of the box
Remove the tape from the outside of the product and check the components that came with your product.
Step two: Attach the control-panel overlay (if not attached)
  1. Position the control panel overlay above the product.
    Kuva : Position the control panel overlay
  2. Press down firmly on all edges and in the center of the overlay to secure it.
    Kuva : Press down firmly
  3. Lift the color graphics display. For best viewing, remove the protective film from the display.
    Kuva : Lift the color graphics display
Step three: Load plain white paper
  1. Remove the output tray.
    Kuva : Remove the output tray
  2. Slide the paper width guide all the way to the left, and then pull the paper length guide as far away from the product as possible.
    Kuva : Slide the paper width and length guides
  3. Insert a stack of plain white letter or A4 paper into the paper tray, and then slide the paper guides snugly against the paper.
    Kuva : Insert paper
  4. Replace the output tray.
    Kuva : Replace the output tray
Step four: Connect the power cord and telephone cord
  1. Connect the power cord and adapter.
    Kuva : Connect the power cord and adapter
  2. Connect one end of the supplied telephone cord to the port on the left (1-LINE) and the other to a wall jack. To connect an answering machine or to use a different telephone cord, see the User Guide.
    Kuva : Connect the telephone cord
Step five: Turn the All-in-One on
Press the On button. The green light flashes, and then becomes solid. This might take up to a minute.
Kuva : The On button
Wait for the cartridge prompt before continuing.
Step six: Install the cartridges
You must leave the product turned on to install or remove the cartridges.
  1. Lift the access door until it stops.
    Kuva : Open the access door
  2. Press down and lift up the green and black latches on the carriage.
    Kuva : Open the latches
  3. Pull the pink tab to remove the tape from both cartridges.
    Kuva : Removing the tape from the cartridges
      varoitus:
    Do not touch the copper-colored contacts or re-tape the cartridges. This can damage the cartridges.
  4. With the label facing up, insert each cartridge into the carriage, and then push it in firmly until it stops.
    • Insert the tri-color cartridge in the left slot
    • Insert the black cartridge in the right slot.
    Kuva : Insert the cartridges
    Kuva : Correct cartridge placement
  5. Push down on the latches to close them, and then close the access door.
  6. Press OK at each of the prompts on the control panel to start the cartridge alignment process.
    The alignment might take a few minutes. After the page prints, alignment is complete.
  7. Check the display for the status, and then press OK. Recycle or discard the alignment page.
Step seven: Set the date and time
Follow these steps if you need to reset the date and time on your product:
  1. Press the Setup button, press 4, and then press 1.
    Kuva : Setup button
  2. Enter the month, day, and year by pressing the appropriate numbers on the keypad. Depending on your country/region setting, you might enter the date in a different order.
  3. Enter the hours and minutes.
    If your time is displayed in the 12-hour format, the AM or PM prompt automatically appears after you enter the last digit.
  4. If prompted, press 1 for AM, or 2 for PM.
    The new date and time settings appear on the display.
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Toiminnot
Ladataan...
Maa/alue: Flag Suomi
Toiminnot
Ladataan...
