4H3A3EA
Victus by HP Laptop 16-e0030ns
AMD Ryzen™ 5 5600H (up to 4.2 GHz max boost clock, 16 MB L3 cache, 6 cores, 12 threads)
AMD Integrated SoC
16 GB DDR4-3200 MHz RAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce RTX™ 3050 Laptop GPU (4 GB GDDR6 dedicated)
512 GB PCIe® NVMe™ TLC M.2 SSD
Optical drive
Optical drive not included
40.9 cm (16.1") diagonal, FHD (1920 x 1080), IPS, micro-edge, anti-glare, 250 nits, 45% NTSC
Realtek Wi-Fi CERTIFIED 6™ (2x2) and Bluetooth® 5.2 combo (Supporting Gigabit data rate)
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4, HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 2 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.1; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37 x 26 x 2.35 cm
2.46 kg
200 W Smart AC power adapter
4-cell, 70 Wh Li-ion polymer
Battery life mixed usage
Up to 10 hours and 30 minutes
Video Playback Battery life
Up to 13 hours and 15 minutes
HP Wide Vision 720p HD camera with integrated dual array digital microphones
Audio by B&O; Dual speakers; HP Audio Boost
- ${title}
- ${title}
- ${title}
- ${title}
Victus by HP Laptop 16-e0030ns Product Specifications
FreeDOS
- ${title}
- ${title}
- ${title}
País/región:
España
- ${title}
hp-hero-support-search
- ${title}
