    ¿Necesita ayuda con Windows 11?
    Vea información sobre compatibilidad, actualización y soluciones para problemas conocidos de HP y Microsoft. Centro de soporte de Windows 11
  • Comentarios
HP X27q QHD Gaming Monitor Product Specifications
Display size
27"
Display size (diagonal)
68.6 cm (27")
Display type
IPS
Panel active area
23.49 x 13.22 in
Brightness
400 nits
Pixel Pitch
0.233 mm
Input connector
1 HDMI 2.0; 1 DisplayPort™ 1.4-in
Scan range (horizontal)
30-255 KHz
Scan range (vertical)
55-165 Hz
Color gamut
99% sRGB
Pixels per inch (ppi)
109 ppi
Screen treatment
Anti-glare
Onscreen controls
Exit; Information; Management; Power control; Input control; Menu control; Gaming; Image; Color
Resolution (maximum)
QHD (2560 x 1440 @ 165 Hz)
Curvature
Flat
Backlight type
Edge-lit
Recommended resolution
2560 x 1440 (QHD)
Aspect ratio
16:9
Contrast ratio
1000:1
Display contrast ratio (dynamic)
10000000:1
Response time
1ms GtG (with overdrive)
Panel bit depth
10 bit (8 bit + FRC)
Height adjustment range
100 mm
Horizontal viewing angle
178°
Vertical viewing angle
178°
Display features
Pivot rotation; Low blue light mode; Anti-glare; Height adjustable; AMD Freesync™ Premium; Gaming Console Compatible
Tilt
-5 to +20°
Resolutions supported
640 x 480; 720 x 400; 800 x 600; 1024 x 768; 1280 x 720; 1280 x 800; 1280 x 1024; 1440 x 900; 1600 x 900; 1680 x 1050; 1920 x 1080; 1920 x 1200; 2560 x 1440
Bezel
3-sided micro-edge
Low blue light
Yes, Eyesafe® Certified
Hardness
3H
Flicker-free
Yes
Internal
Power consumption
70 W (maximum), 28 W (typical), 0.5 W (standby)
Power supply
100 - 240 VAC 50/60 Hz
Connectivity and Communications
DisplayPort™
1 DisplayPort™ 1.4
Audio port
1 x 3.5 mm Audio Jack (Audio Out)
HDMI
1 HDMI 2.0
Weight and Dimensions
6.3 kg
Dimensions
61.35 x 5.05 x 36.63 cm
Box contents
What's in the box?
Monitor; DisplayPort™ cable; Warranty card; Product notice; AC power cord
País/región: Flag España
