    Solucione errores intermitentes en la cola de impresión/con el spooler de impresión que podrían causar fallos en los trabajos de impresión tras una actualización de Windows. Haga clic aquí
    Corrija errores en Win 10
HP Tablets - Setting up Your HP Tablet (Android 5.0/Lollipop)
This document applies to HP and Compaq tablets with Android 5.0/Lollipop operating system.
This document provides information about setting up your HP tablet for the first time, setting up the Internet connection, and adding your owner account.
Setting up your HP tablet for the first time
Complete the following steps to set up the tablet:
  1. Unpack the box and remove any packaging material from the tablet and power supply.
  2. Connect the charging cable to the tablet.
  3. Connect the power adapter to a power outlet.
  4. Remove the protective film from the screen.
  5. Turn on the tablet. Press and hold the power button until the HP logo appears on the screen. The power button is located on the back of the tablet, on the top right side.
After turning on the tablet, a Welcome screen displays. Continue using the steps in this document to complete the setup process.
Step 1: Selecting a preferred language
Select your preferred language on the welcome screen.
  1. Swipe up or down on the touchscreen to scroll through the language menu until your preferred language is highlighted.
    Figura : Language menu
    Language menu
    If your preferred language does not appear in the list, you can download and install the language after completing setup by going to the Google Play Store (in English).
  2. Tap the forward arrow to proceed to the next screen.
Step 2: Setting up a Wi-Fi connection
Connecting to the Internet during the initial setup is optional, however if you choose not to set up a Wi-Fi connection, the tablet is limited in functionality until you establish a connection. Without Internet, you cannot sign in using a Google Account, and cannot update software or download apps.
If your wireless router requires that you enter a MAC address to connect, use a different Wi-Fi network, or skip connecting to Wi-Fi for the initial setup. Follow the steps for finding your MAC address in the HP support document Connecting to a Wireless Network.
To skip past the Select Wi-Fi page, tap Skip, and then tap Skip anyway. Follow the on-screen instructions to continue setting up the tablet.
Use the following steps to connect to a Wi-Fi network during the initial setup process:
Some Wi-Fi networks (in hotel rooms, for example) feature an online sign-in page that requires you to access the Internet in order to sign in. When connecting to Wi-Fi for the first time (during the setup process), do not use a Wi-Fi network that features an online sign-in page.
  1. On the Select Wi-Fi screen, tap your Wi-Fi network in the list of available networks.
    If you are trying to connect to a hidden Wi-Fi network during the setup process, and the tablet does not discover or connect to the network, temporarily unhide the network until setup is complete.
    Figura : Select Wi-Fi
    Select Wi-Fi
  2. If a password is required, enter your password, and then tap Connect. Continue to the next step to set up an account.
Step 3: Setting up an account
When you sign in using your primary Google Account email address and password, you are automatically signed in to all the Google sites and services associated with that account (for example, Gmail and Google Play). The first account added to the tablet is the owner account, and includes special permissions (for example, the ability to delete other user accounts stored on the tablet, and the ability to reset the tablet). After adding an account during the initial setup, up to seven (7) additional user accounts can be added to the tablet.
Use the steps in one of the following sections to set up an account on your tablet with an existing Google Account, with a new Google Account, or without using a Google Account:
Step 4: Completing setup and registering your product
When you reach the Register screen, read and agree to HP's license terms, enter your email address in the field provided, and then tap Accept.
To bypass registration tap the X next to Clear All, and then tap Accept.
Figura : Register
Register
The tablet is set up and ready to use.
Additional Resources
Browse to Books on Google Play (in English) and enter lollipop quick start in the search field to download the Android Quick Start Guide, Android 5.0, Lollipop PDF.
País/región: Flag España
