HP t620 Flexible Thin Client
Feature
Processor
Storage
16-64GB MLC mSATA SSD
Memory
Graphics
Communication
Audio
Ports and connectors
Power
65W worldwide auto-sensing 100-240 VAC 50-60Hz surge-tolerant power supply
Input devices
Output
Input
Audio CODECS with hardware acceleration support
Video CODECS with hardware acceleration support
ThinPro
HP Smart Zero Technology
WES 7E
WES 7P
WES 8
Flash (boot drive) SSD
16GB
16GB
16GB
16GB
16GB
Standard system memory
4GB
4GB
4GB
4GB
4GB
System memory reserved for graphics (minimum)
512MB
Maximum system memory (memory speed is 1600 MHz)
16GB DDR3L 1600 MHz (8GB x 2)
4GB DDR3L 1600 MHz (4GB x 1)
Memory slots
2 SODIMMs
Connector
RJ-45
Data rates supported
Management
HP Fast Ethernet Mini PCIe SC Fiber Network Interface Card (factory-installed option)
Adapter
Allied Telesis AT-27MINI Fast Ethernet Fiber PCI Express MINI Network Interface Card
Form factor
Custom-designed card plugs into PCI-Express Mini Card slot, and mounts into device bay inside HP t620 chassis
Management features
Ethernet
Network controller
Broadcom BCM57762
Connectors
SC
Power consumption
2 W(typical)
Compliance
115 V ac (60 Hz)
230 V ac (50 Hz)
100 V ac (60 Hz)
Standard models (dual core)1
Idle state
4.4236 W
4.5105 W
4.4132 W
Sleep state
0.6241 W
0.6653 W
0.6153 W
Off mode
0.4825 W
0.5287 W
0.4811 W
Standard models (quad core)2
Idle state
4.9246 W
4.993 W
4.9151 W
Sleep state
0.5738 W
0.6337 W
0.5747 W
Off mode
0.4153 W
0.4601 W
0.4132 W
nota: |
Efficiency
65 W
Voltage range
Worldwide auto-sensing 100 - 240 V ac
Line frequency
50 - 60 Hz
Standard chassis vertical orientation with stand
(H x W x D)
240 x 220 x 40 mm (9.5 x 8.7 x 1.6 in)
Standard chassis with stand
1.36 kg (3 lb)
Feature
Operating system preinstalled1
Temperature range
Humidity
nota: |
Ergonomics
Approved
Safety
RF interference
Eco-Label Certifications &
declarations
nota: |
