- ${title}
- ${title}
- ${title}
- ${title}
HP EliteBook 840 G1 Notebook PC Product Specifications
Product features
Feature
Processors
4th generation Intel Core Processors
Chipset integrated with processor
Graphics
Integrated:
Discrete:
Internal:
External: Up to 32-bit per pixel color depth
VGA: Port supports resolutions up to 1920 x 1200 external resolution at 75 Hz
Storage and drives
Hard drives
Solid State Drives
Memory
Standard
Maximum
Dual-channel
Networking/Communications
Broadband wireless (WWAN)
Wireless LAN (WLAN)
Communications
Audio/Multimedia
Audio
Optional 720p HD webcam
Power supply
Integrated graphics:
Discrete graphics:
Ports/Slots
Ports:
Expansion slots:
Physical specifications
Specification
Starting at 1.58 kg (3.48 lb) (non-Touch) (weight will vary by configuration)
Starting at 1.78 kg (3.92 lb) (Touch) (weight will vary by configuration)
Dimensions (w x d x h)
Non-Touch
33.89 x 23.7 x 2.10 cm (13.34 x 9.33 x 0.83 in)
Touch
33.89 x 23.7 x 2.25 cm (13.34 x 9.33 x 0.89 in)
Display specifications
12.5-inch diagonal LEDbacklit
HD anti-glare SVA
flat (1366 x 768)
Specification
Outline dimensions (W x H x D)
29.1 x18.14 x 0.36 cm (11.46 x 7.14 x 0.14 in)
Active area
27.6615 x 15.552 cm (10.89 x 6.12 in)
270 g (0.6 lb) (max)
Diagonal size
35.75 cm (12.5 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
125 ppi
Viewing angle
SVA 40/40/15/30 (Left/Right/Down/Up)
HD Premium antiglare
UWVA slim (1366 x
768)
Specification
29.1 x18.14 x 0.285 cm (11.46 x 7.14 x 0.112 in)
Active area
27.559 x 15.494 cm (10.85 x 6.12 in)
220 g (0.49 lb) (max)
Diagonal size
35.75 cm (12.5 in)
Surface treatment
Anti-glare
Contrast ratio
500:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
IPS/FFS/VA
PPI
125 ppi
Viewing angle
UWVA 85/85/85/85 (Left/Right/Down/Up)
14-inch diagonal LED-backlit
HD anti-glare SVA flat
(1366 x 768)
Specification
32.09 x 20.56 x 0.36 cm (12.6 x 8.09 x 0.14 in)
Active area
30.94 x 17.395 cm (12.18 x 6.85 in)
320 g (0.71 lb) (max)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
125 ppi
Viewing angle
HD+ anti-glare SVA flat
(1600 x 900)
Specification
Active area
30.96 x 17.415 cm (12.19 x 6.86 in)
325 g (0.72 lb) (max)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
131 ppi
Viewing angle
HD+ SVA flat + touch
(1600 x 900)
Specification
Active area
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
250 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
131 ppi
Viewing angle
FHD anti-glare UWVA slim
(1920 x 1080)
Specification
32.09 x 20.56 x 0.3 cm (12.6 x 8.09 x 0.12 in)
Active area
30.93 x 17.4 cm (12.18 x 6.85 in)
340 g (0.75 lb) (max)
Diagonal size
35.6 cm (14.0 in)
Surface treatment
Anti-glare
Contrast ratio
600:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
Interface
eDP 1.3+PSR (2 lane)
LCD mode
IPS/FFS/VA
PPI
157 ppi
Viewing angle
15.6- inch diagonal LEDbacklit
HD anti-glare SVA
flat (1366 x 768)
Specification
36.0 x 22.43 x 0.38 cm (14.17 x 8.83 x 0.15 in)
Active area
34.42 x 19.35 cm (13.55 x 7.62 in)
500 g (Less than 1.1 lb) (max)
Diagonal size
39.62 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
300:1 (min)
Refresh rate
60 Hz
Brightness
200 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
101 ppi
Viewing angle
15.6-inch diagonal LEDbacklit
FHD anti-glare SVA
flat (1920 x 1080)
Specification
Active area
34.42 x 19.36 cm (13.55 x 7.62 in)
380 g (Less than 0.84 lb) (max)
Diagonal size
39.62 cm (15.6 in)
Surface treatment
Anti-glare
Contrast ratio
400:1 (min)
Refresh rate
60 Hz
Brightness
300 nits (typical)
Pixel resolution
Interface
eDP 1.2 (1 lane)
LCD mode
TN
PPI
142 ppi
Viewing angle
SVA 45/45/25/35 (Left/Right/Down/Up)
System specifications
Specification
Stand-alone power requirements (AC Power)
Max operating power: Discrete less than 90 W
UMA: less than 65 W
Temperature
Operating:
Non-operating:
-20° to 60°C (-4° to 140°F)
Relative humidity
Operating: 10% to 90%, non-condensing
Non-operating: 5% to 95%, 38.7°C (101.6°F) maximum wet bulb temperature
Shock
Operating: 40 G, 2 ms, half-sine
Non-operating: 200 G, 2 ms, half-sine
Random vibration
Operating: 0.75 g
Non-operating: 1.50 g
Altitude (unpressurized)
Operating: -15.24 to 3,048 m (-50 to 10,000 ft)
Non-operating: -15.24 to 12,192 m (-50 to 40,000 ft)
Planned industry standard
certifications
HDD specifications
320GB 5400 rpm SATA
Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
ATA-8, SATA 2.6, 3.0 Gb/s, NCQ
Transfer rate
Synchronous (maximum): 300 Mb/s (Drive Capability)
Seek time
(typical reads, including settling)
Rotational speed
7200 rpm
Logical blocks
625,142,448
Operating temperature
0° to 60°C (32° to 140°F) [case temp]
Features
ATA Security
1TB 5400 rpm
SATA Hard Drive
Specification
Drive weight
115 g (0.254 lbs)
Capacity
1TB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
Rotational speed
5400 rpm
Logical blocks
1,953,525,168
Features
ATA Security
500GB 5400 rpm SATA
FIPS Hard Drive
(Expected to be available in
November 2013)
Specification
Drive weight
95 g (0.25 lbs)
Capacity
500GB
Height
7 mm (0.28 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
Cache
16MB
Rotational speed
5400 rpm
Logical blocks
976,773,168
Features
ATA Security
320GB 7200 rpm SATA
Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
320GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
625,142,448
Features
ATA Security
500GB 7200 rpm SATA
Hard Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
70 mm (2.75 in)
Interface
Transfer rate
Seek time
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security
500 GB 7200 rpm SMART
SATA II Self Encrypting
Drive
Specification
Drive weight
115 g (0.25 lbs)
Capacity
500GB
Height
9.5 mm (0.37 in)
Width
63.5 mm (2.75 in)
Interface
Transfer rate
Seek time
Cache
16MB
Rotational speed
7200 rpm
Logical blocks
976,773,168
Features
ATA Security
SATA 6 Gb/s 128GB 2.5-inch Solid State Drive
Specification
Drive weight
73 g
Capacity
128GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
Logical blocks
250,069,680
0° to 70°C (32° to 158°F) [case temp]
Features
ATA Security; ATA-8; SATA 3.0; DIPM; TRIM
SATA 6 Gb/s 180GB 2.5-inch SATA Solid State
Drive
Specification
Drive weight
73 g
Capacity
180GB
Height
7 mm (0.276 in)
Width
70 mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
Logical blocks
351,651,888
Features
ATA Security; ATA-8, SATA 3.0; DIPM; TRIM
SATA 6 Gb/s 240GB 2.5-inch Solid State Drive
Specification
Drive Weight
78 g
Capacity
240GB
Height
7 mm (0.276 in)
Width
70mm (2.76 in)
Interface
SATA Gen 3 (6 Gb/s)
Performance
Logical blocks
468,862,128
Operating Temperature
Features
SATA 6 Gb/s 256GB, 2.5-inch SATA SED Solid State
Drive (Expected to be
available in November
2013)
Specification
Drive Weight
78 g
Capacity
256GB
Height
7 mm (0.276 in)
Width
70mm (2.76 in)
Interface
SATA 3 (6 Gb/s)
Performance
Logical blocks
500,118,192
Features
ATA Security; ATA-8 compliant; SATA 3.0; DIPM; TRIM
SATA 6Gb/s 120GB, 2242
M.2 Solid State Drive (Expected to be available in
November 2013)
Specification
Drive Weight
Up to 10 g
Capacity
120GB
Height
3.5 mm (0.138 in)
Width
22mm (0.866 in)
Interface
M.2 SATA Gen3 (6 Gb/s)
Performance
Logical blocks
234,441,648
Features
HP 3110 HSPA+ Mobile
Broadband Module
Specification
Maximum power
consumption
2700 mA (peak)
Power consumption
Sleep mode: 10 mA
Antenna type
Dual high efficiency 6 band antennae with spatial diversity, mounted in the
display enclosure
Form factor
PCI-Express MiniCard, USB 2.0 interface
Less than 10 g
Dimensions (Length x
Width x Thickness)
51 x 30 x 4.5 mm (2.01 x 1.18 x 0.18 in)
Voltage
Operating: 3.3 V +/- 9%
Temperature
Operating: -20° to 65°C (-4° to 149°F)
Non-operating, 96 hours (from
MIL-STD 202 Method 108): -40° to 85°C (-40° to 185°F)
Humidity
Non-operating: 85% relative humidity for 48 hours at 185°F (85°C) (non-condensing)
LED activity
LED Off - Radio Off
Solid LED On - Radio On
HP lt4111 LTE/EVDO/
HSPA+ 4G WWAN
Specification
Maximum power
consumption
LTE: 1,200 mA (peak); less than 900 mA (average)
WCDMA: 1,100 mA (peak); less than 800 mA (average)
EGPRS: 2,500 mA (peak); less than 700 mA (average)
Power consumption
Sleep mode: 2 mA
Antenna type
Dual high efficiency multi-band antennae with spatial diversity
Form factor
M.2, 3042-S3 Key B
6 g
Width x Thickness)
42 × 30 × 2.3 mm
Voltage
Operating: 3.135 V to 4.4 V (3.3 V +1.1 V/-0.165 V)
Temperature
Operating (from TIA/EIA/IS-98-D): -25° to 60°C (-13° to 140° F)
Humidity
Non-operating: 95% relative humidity for 48 hours at 185°F (85°C) (non-condensing)
LED activity
LED Off - Radio Off
HP lt4112 LTE/HSPA+
Gobi 4G Module
Specification
Maximum power
consumption
Power consumption
Sleep mode: 3 mA
Antenna type
Form factor
M.2, USB 2.0 interface
6 g
Width x Thickness)
42 × 30 × 2.3 mm
Voltage
Temperature
Operating (from TIA/EIA/IS-98-D): -10° to 55°C (14° to 131°F)
Humidity
LED activity
LED Off - Radio Off
Broadcom 802.11 a/b/g/n
(2x2) with Bluetooth
v4.0 combo
Specification
Power consumption
Transmit: 2.0 W (max)
Receive: 1.6 W (max)
Idle mode (PSP): 250 mW (WLAN Associated)
Idle mode: 100 mW (WLAN unassociated)
Radio disabled: 75 mW
Antenna type
High efficiency antenna with spatial diversity, mounted in the display
enclosure
Two embedded dual band 2.4/5 GHz antennas are provided to the card to
support WLAN MIMO communications and Bluetooth communications
Form factor
PCI-Express Half-MiniCard
3.1 g
Dimensions
4.75 x 26.8 x 30 mm (0.19 x 1.06 x 1.18 in)
Voltage
Temperature
Operating: -10° to 70°C (14° to 158°F)
Non-operating: -40° to 80°C (-40° to 176°F)
Humidity
Operating: 10% to 90% (non-condensing)
Non-operating: 5% to 95% (non-condensing)
Altitude
Operating: 3,048 m (0 to 10,000 ft)
Non-operating: 15,240 m (0 to 50,000 ft)
LED activity
LED Off - Radio Off
Intel Dual Band Wireless-
N 7260AN 802.11 a/b/g/n
(2x2) WiFi + Bluetooth 4.0
Combo Adaptor
Specification
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Antenna connections
2 U.FL type connectors (output impedance of 50 ± 2 ohms)
Form factor
3.1 g
Dimensions
3.1 x 26.8 x 30.0 mm (0.12 x 1.06 x 1.18 in)
Voltage
Temperature
Humidity
Altitude
LED activity
LED Off - Radio Off
AC 7260 802.11 ac (2x2)
WiFi + BT 4.0 combo
Adapter
Specification
Power consumption
Antenna type
enclosure
Form factor
3.1 g
Dimensions
Voltage
Temperature
Humidity
Altitude
LED activity
LED Off - Radio Off
N 7260NB 802.11 a/b/g/n
(2x2) WiFi Adapter
Specification
Power consumption
Transmit: 2.0 W
Receive: 1.6 W
Antenna connections
Form factor
3.1 g
Dimensions
Voltage
Temperature
Humidity
Altitude
LED activity
LED Off - Radio Off
Audio/Multimedia
Specification
Implementation
IDT 92HD91
Function key
volume controls
Volume up, volume down, and mute
Full duplex
Yes
Microphone In
Stereo
Headphone/Line out
Stereo
Integrated microphone
Yes, dual digital microphone array when equipped with optional webcam
Audio output quality
Specification
Frequency response
20 Hz - 20 kHz
Signal to noise ratio
>85 dB
Total harmonic distortion
0.01%
Noise floor
-110 dB
Play/Record sampling
rate(s)
8 kHz - 48kHz
DAC
16, 20 or 24-bit
ADC
16 or 20-bit
Integrated stereo
speakers
Specification
Power rating
2 W
Impedance
4 Ohms
Fingerprint Reader
HP Fingerprint Reader
(optional)
Specification
Mobile voltage operation
3.0 V - 3.6 V
-10° - 75°C (14° - 167°F)
Current consumption
36 mA peak
Low latency wait for
finger
950 uA
Capture rate
3000. lines/sec
ESD resistance
IEC 61000-4-2 4B (±15KV)
Detection matrix
200*1 (plus another secondary line)
508 dpi
12*3 mm sensor area
Power specifications
HP 45W Smart AC Adapter
Specification
Dimensions
9.6 x 4.95 x 2.24 cm (3.78 x 1.95 x 0.88 in)
Input
90 to 265 V ac
Output
Connector
3 pin/grounded, mates with interchangeable cords
Environmental design
EMI and Safety
Certifications
CE Mark - full compliance with LVD and EMC directives; Worldwide safety
standards - IEC60950, EN60950, UL60950, Class1, SELV; Agency approvals -
C-UL-US, NORDICS, DENAN, EN55022 Class B, FCC Class B, CISPR22 Class B,
CCC, NOM-1 NYCE; Reliability - failure rate of less than 0.1% annually within
the first three years of operation.
HP 65W EM Smart AC
Adapter
Specification
Dimensions
12.65 x 5.0 x 3.0 cm (4.98 x 1.97 x 1.18 in)
290 g (0.62 lb) max
Input
90 to 265 V ac
Output
Connector
EMI and Safety
Certifications
CCC, NOM-1 NYCE; MTBF - over 200,000 hours at 25°C ambient condition.
HP 65W Smart AC Adapter
Specification
Dimensions
10.6 x 4.7 x 2.8 cm (4.17 x 1.85 x 1.1 in)
280 g (0.62 lb)
Input
100 to 240 V ac
Output
Connector
EMI and Safety
Certifications
3-cell HP Long Life
(24WHr) Lithium-Ion
Polymer
Specification
Dimensions (H x W x L)
2.16 x 4.46 x 26.9 cm (0.85 x 1.76 x 10.59 in)
Cells/Type
3-cell Lithium-Ion Polymer
Energy
Temperature
Fuel gauge LED
No
1 year
Optional travel battery
available
No
3-cell HP Long Life
(26WHr) Lithium-Ion
Polymer
Specification
Cells/Type
Energy
Temperature
Fuel gauge LED
No
1 year
available
No
3-cell HP Long Life
(46WHr) Lithium-Ion
Polymer
Specification
Cells/Type
Energy
Temperature
Fuel gauge LED
No
1 year
available
No
3-cell HP Long Life
(50WHr) Lithium-Ion
Polymer
Specification
Cells/Type
Energy
Temperature
Fuel gauge LED
No
1 year
available
No
HP 6-cell Lithium-Ion
Long Life Slice Battery (60
WHr)
Specification
0.78 kg (1.72 lb)
Cells/Type
6-cell Lithium-Ion
Energy
Temperature
Battery
Re-Charge time
Fuel gauge LED
No
available
No
Software overview
Feature
Preinstalled.
Preinstalled software with windows operating system
BIOS:
- ${title}
- ${title}
- ${title}
País/región:
España
- ${title}
hp-hero-support-search
- ${title}
