    ¡Cree una cuenta HP hoy!
HP EliteBook 2540p Notebook PC - Removing and Replacing the 2.5-inch Storage Drive
This document is provided to assist in removing and replacing the 2.5-inch storage drive for the HP EliteBook 2540p Notebook PC.
Minimum skill level
The End-User should possess product-specific knowledge and technical skill on how to service the system, and have familiarity with the operating system.
Tools required
Small, Phillips-head (P00 and P1) screwdrivers
Parts required
The replacement part number will vary depending on the 2.5-inch storage drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
80GB solid-state drive (SSD) - SATA interface, 2.5-inch form factor - For use only in the optical drive bay (Requires separate hard drive carrier)
602676-001 (Modified)
Yes
160GB solid-state drive (SSD) - SATA interface, 2.5-inch form factor - For use only in the optical drive bay (Requires separate hard drive carrier)
598783-001 (Modified)
Yes
250GB SATA II hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - For use only in the optical drive bay (Requires separate hard drive carrier)
598779-001 (Modified)
Yes
320GB SATA II hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - For use only in the optical drive bay (Requires separate hard drive carrier)
598780-001 (Modified)
Yes
500GB SATA II hard disk drive - 7,200 RPM, 2.5-inch form factor, 9.5 mm height - For use only in the optical drive bay (Requires separate hard drive carrier)
598781-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the 2.5-inch storage drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select 2.5-inch Storage drive from the menu on the upper left hand side of the screen.
Click here to view the 2.5-inch storage drive removal video(right-click on the link to open in a new window/tab).
2.5-inch Storage drive removal
      atención:
  2. Remove the 2.5-inch storage drive carrier.
  3. Remove the four 3 mm P1 Phillips-head screws that secure the 2.5-inch storage drive in the 2.5-inch storage drive carrier.
  4. Carefully lift the outside edge of the 2.5-inch storage drive until it clears the bezel and slide it toward the bezel to disconnect the 2.5-inch storage drive from its connector on the 2.5-inch storage drive carrier.
  5. Remove the 2.5-inch storage drive from the 2.5-inch storage drive carrier.
  6. Place the 2.5-inch storage drive in a static dissipative bag.
2.5-inch Storage drive replacement
  1. Remove the 2.5-inch storage drive from the static dissipative bag.
  2. At an angle, carefully toe the 2.5-inch storage drive into the 2.5-inch storage drive carrier and connect the 2.5-inch storage drive to its connector on the 2.5-inch storage drive carrier.
  3. Lower the 2.5-inch storage drive into the 2.5-inch storage drive carrier.
  4. Replace the four 3 mm P1 Phillips-head screws that secure the 2.5-inch storage drive in the 2.5-inch storage drive carrier.
  5. Replace the 2.5-inch storage drive carrier.
Parts return
País/región: Flag España
