    ¡Cree una cuenta HP hoy!
HP EliteBook 2540p Notebook PC - Removing and Replacing the 1.8-inch Storage Drive
This document is provided to assist in removing and replacing the 1.8-inch storage drive for the HP EliteBook 2540p Notebook PC.
Minimum skill level
Parts required
The replacement part number will vary depending on the 1.8-inch storage drive that is being replaced. If a part is listed as "Yes" under "Requires Return" then the defective part needs to be returned to HP. Click here for more information on returning parts to HP.
Part Number
Requires Return
80GB solid-state drive (SSD) - SATA interface, 1.8-inch form factor - For use only in the hard drive bay, and on computer models equipped with a low-voltage (25 W) processor
602675-001 (Modified)
Yes
160GB solid-state drive (SSD) - SATA interface, 1.8-inch form factor - For use only in the hard drive bay, and on computer models equipped with a low-voltage (25 W) processor
598782-001 (Modified)
Yes
160GB SATA II hard disk drive - 5,400 RPM, 1.8-inch form factor, 9.5mm height - With bracket - For use only in the hard drive bay, and on computer models equipped with a low-voltage (25 W) processor
598777-001 (Modified)
Yes
250GB SATA II hard disk drive - 5,400 RPM, 1.8-inch form factor, 9.5mm height - With bracket - For use only in the hard drive bay, and on computer models equipped with a low-voltage (25W) processor
598778-001 (Modified)
Yes
Summary of instructions
To view a video demonstrating the procedure for removing the 1.8-inch storage drive, click on the link below. Or use the product video listing on the HP Services Media Library, (Click here to go to HP Service Media Library), then select 1.8-inch Storage drive from the menu on the upper left hand side of the screen.
Click here to view the 1.8-inch storage drive removal video (right-click on the link to open in a new window/tab).
1.8-inch Storage drive removal
      atención:
  2. Remove the 1.8-inch storage drive carrier.
  3. Disconnect the storage drive connector board from its connector on the 1.8-inch storage drive.
  4. Remove the rubber gasket that surrounds the 1.8-inch storage drive.
  5. Place the 1.8-inch storage drive in a static dissipative bag.
1.8-inch Storage drive replacement
  1. Remove the 1.8-inch storage drive from the static dissipative bag.
  2. Wrap the rubber gasket around the 1.8-inch storage drive.
  3. Connect the storage drive connector board into its connector on the 1.8-inch storage drive.
  4. Replace the 1.8-inch storage drive carrier.
Parts return
País/región: Flag España
