- ${title}
- ${title}
- ${title}
- ${title}
HP Deskjet 1050, 1050A, 2050, and 2050A All-in-One Printer Series - Setting up the All-in-One (Hardware)
Unpack the All-in-One
Check the contents of the box
Connect the power cord and adapter
Turn on power
Load plain paper
Install the cartridges
Align the cartridges
Follow these steps in order.
Remove the tape and cardboard from the outside the product, and then open it.Figura : Remove tape from the outside of the product
Open the front access door, open the cartridge access door, and then remove the tape and cardboard from the inside the product.Figura : Remove the tape and cardboard from inside the printer
Close the cartridge access door.Figura : Close the cartridge access door
Raise the input tray.Figura : Raise the input tray
Pull out the tray extender.Figura : Pull out the tray extender
Step three: Connect the power cord and adapter
Connect the power cord into the rear of the product.Figura : Connect the power cord into the rear of the product
Connect the power cord to the power supply, and then into a power outlet in the wall.Figura : Connect the power cord to the power supply, and then into a power outlet in the wall
Step four: Turn on power
Press the Power button (
) to turn the product on.
Figura : Turn on the product
Step five: Load plain paper
Slide the paper width guide to its outermost position.
Load a stack of 216 x 279 mm (8.5 x 11 in) plain paper into the paper tray, print-side down. Slide the stack of paper in until it stops.
Slide the paper width guide snugly against the paper.Figura : Load paper, and then adjust the paper width guide
Step six: Install the cartridges
) to turn on the product, if it is not already turned on. Wait until the product is idle and silent before continuing.
Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing.Figura : Open the cartridge access door
Remove the new cartridge from its packaging, and then carefully pull the pink pull tab to remove the plastic tape.
atención:
Do not touch the copper-colored contacts or ink nozzles. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.Figura : Remove the plastic tape -
Hold the cartridge by its sides with the nozzles toward the product, and then insert the cartridge into its slot. Make sure that the icon on the cartridge matches the icon on the slot.
The tri-color cartridge (
) goes in the slot on the left
The black cartridge (
) goes in the slot on the right
Figura : Insert the black cartridge into the slot on the right -
Push the cartridge forward into its slot until it snaps into place.Figura : Snap the cartridge into place
Repeat these steps to insert the other cartridge.
Wait about 30 seconds for the alignment page to automatically print.Figura : The alignment page prints automatically after 30 seconds
Step seven: Align the cartridges
Lift the scanner lid.
Place the alignment page with the printed-side down on the right-front corner of the scanner glass. See the engraved guide next to the scanner glass for help loading the alignment page.Figura : Place the alignment page on the scanner glass
Close the scanner lid.
Press the Start Copy Black button (
) to begin the scan. The product automatically aligns the cartridges.
Wait until the Power light (
) stops blinking, which indicates that the cartridge alignment is complete.
- ${title}
- ${title}
- ${title}
País/región:
España
- ${title}
hp-hero-support-search
- ${title}
