    ¿Necesita ayuda con Windows 11?
    Vea información sobre compatibilidad, actualización y soluciones para problemas conocidos de HP y Microsoft. Centro de soporte de Windows 11
  • Comentarios
HP Officejet 4500 (G510) Series and 4500 (K710) Series All-in-One Printers - Loading 102 x 152 mm (4 x 6 inch) Photo Paper
This document provides instructions for loading 102 x 152 mm (4 x 6 inch) photo paper.
Video of loading photo paper
The following video demonstrates the steps for loading photo paper in the HP Officejet 4500.
Some Officejet 4500 All-in-One printer models do not have an automatic document feeder (ADF), so your product might look slightly different than the one shown.
Load photo paper
Follow these steps to load 102 x 152 mm (4 x 6 inch) photo paper.
  1. Remove any paper from the paper tray.
  2. Load a stack of photo paper into the rightmost side of the paper tray, print-side down. Slide the stack of paper forward until it stops.
  3. Slide the paper width guide inward until it stops at the edge of the paper.
País/región: Flag España
