    ¡Cree una cuenta HP hoy!
HP Officejet J4500 and J4600 Printers - Loading Paper
This document is for HP Officejet J4524, J4525, J4535, J4540, J4550, J4580, J4585, J4624, J4660, J4680, and J4680c All-in-One Printers.
Load paper into the main input tray.
  1. If the product is printing, wait for it to stop, and then move the paper-width guide to its outermost position.
  2. Insert the stack of paper print-side down along the right side of the paper tray.
    Make sure that the stack of paper aligns with the right and back edges of the tray, and fits below the line marking in the tray.
  3. Slide the paper-width guide inward until it stops at the edge of the stack of paper.
    Figura : Adjusting the paper guides
  4. Pull out the tray extender.
    Figura : Extending the paper tray extender
País/región: Flag España
