    ¡Cree una cuenta HP hoy!
HP Photosmart C5200 Series - Installing the Print Cartridges
This document describes how to install the print cartridges.
Installing the print cartridges
The product must be turned on and the CD/DVD tray must be in the up position before you can insert the cartridges.
  1. Lift the cartridge door.
    Figura : Raise the cartridge door
    Raise the top cover of the product
  2. Remove the tape from the cartridges.
    Figura : Remove the tape
    Remove protective tape from cartridges
      atención:
    Do not touch the copper-colored contacts or re-tape the cartridges.
    Figura : Do not touch ink nozzles or copper-colored contacts
    Do not touch electrical contacts or ink nozzles
  3. With the HP logo on top, insert the tri-color cartridge in the left slot and the black or photo cartridge in the right slot.
    Figura : Insert the tri-color cartridge
    Insert the tri-color cartridge in the left slot
  4. Push the cartridges in firmly until they snap into place.
    Figura : Push each cartridge in firmly
    Push each cartridge firmly into place
    Figura : Correctly installed cartridges
  5. Close the cartridge door.
  6. Press OK when prompted to confirm the installation of genuine HP cartridges.
País/región: Flag España
