    ¿Necesita ayuda con Windows 11?
    Vea información sobre compatibilidad, actualización y soluciones para problemas conocidos de HP y Microsoft. Centro de soporte de Windows 11
  • Comentarios
HP Officejet 5600 All-in-One Printer Series- Setting up the All-in-One (Hardware)
  • Unpack the All-in-One
  • Attach the control panel faceplate
  • Attach the trays and load paper
  • Connect the power cord and adapter
  • Connect the supplied phone cord
  • Select the language/region
  • Install the cartridges
  • Align the cartridges
Follow these steps in order.
Remove all tape and cardboard packing material from the outside and inside of the product.
Figura : Remove all packing materials
Step three: Attach the control panel faceplate
The control panel faceplate must be in place for the product to work. If the control panel faceplate is not already attached, do the following:
  1. Align the faceplate over the buttons on the top of the product.
    Figura : Align the faceplate
    Align the faceplate
  2. Snap the faceplate firmly into place.
Step four: Attach the trays and load paper
  1. Insert the tabs of the bottom tray into the product, and then lower the tray until it is flat.
    Figura : Insert the bottom tray
  2. Slide the paper adjuster to the left.
    Figura : Slide the paper adjuster to the left
  3. Insert plain white paper.
    Figura : Load plain paper
    Load plain paper
  4. Insert the top edge of the output tray into the light gray latches, and then lower it.
    Figura : Attach the output tray
  5. Open the paper tray extender.
    Figura : Open the tray extender
Step five: Connect the power cord and adapter
  1. Plug the printer end of the power adapter into the back of the product.
  2. Plug the adapter end of the power cord into the power adapter.
  3. Plug the remaining end of the power cord into a grounded wall outlet or surge protector.
Figura : Connect the power cord and adapter
Step six: Connect the supplied phone cord
  1. Connect one end of the supplied phone cord to the phone port on the left (1-LINE) and the other to a wall jack.
    Figura : Connect the phone cord
  2. On the HP All-in-One control panel, press the On button ().
    The green light flashes, and then becomes solid. This might take up to a minute.
Step seven: Select the language/region
  1. When prompted, use the arrow keys to select your language, press OK, and then confirm.
  2. When prompted, use the arrow keys to select your country/region, press OK, and then confirm.
Step eight: Install the cartridges
  1. Lower the access door, and then wait for the carriage that holds the cartridges to move to the right side.
    Figura : Lower the access door
    Figura : The carriage
    The carriage that holds the cartridges
  2. Pull the pink tab to remove the tape from both cartridges.
      Figura : Remove the tape
      Remove the protective tape
    1. Copper-colored contacts
    2. Plastic tape with pink pull tab (must be removed before installing)
    3. Ink nozzles under tape
      atención:
    Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
    Figura : Do not touch the electrical contacts or ink nozzles
  3. Slide each new cartridge forward into its empty slot, and then gently push on the upper part of the cartridge until it snaps into place.
    • Insert the tri-color cartridge into the left slot.
    • Insert the black or photo cartridge into the right slot.
    Figura : Insert the cartridges
  4. Close the access door.
    Figura : Close the access door
Step nine: Align the cartridges
After you insert the cartridges, a message displays indicating that the product is ready for alignment.
País/región: Flag España
