    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP Pavilion Gaming Laptop - 16-a0097nr Product Specifications
2Z778UA
Intel® Core™ i7-10750H (2.6 GHz base frequency, up to 5 GHz with Intel® Turbo Boost Technology, 12 MB L3 cache, 6 cores)
16 GB DDR4-2933 SDRAM (2 x 8 GB)
  • 512 GB Intel® SSD
  • [16]
Optical drive
Optical drive not included
16.1" diagonal FHD, 144 Hz, IPS, anti-glare, micro-edge, WLED-backlit, 300 nits, 72% NTSC (1920 x 1080)
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
1 SuperSpeed USB Type-C® 5Gbps signaling rate (DisplayPort™ 1.4); 1 SuperSpeed USB Type-A 5Gbps signaling rate (HP Sleep and Charge); 1 SuperSpeed USB Type-A 5Gbps signaling rate; 1 HDMI 2.0; 1 RJ-45; 1 AC smart pin; 1 headphone/microphone combo
37 x 26.25 x 2.35 cm
2.34 kg
200 W Smart AC power adapter
3-cell, 52.5 Wh Li-ion
HP TrueVision HD camera with integrated dual array digital microphone
Audio by B&O; Dual speakers
HP Audio Switch; HP BIOS Protection; HP Connection Optimizer; HP JumpStart; OMEN Command Center; HP Support Assistant
Pre-installed software
Netflix
Country/Region: Middle East
