Document ID: c04027033
Version: 1
HP ZBook 15-Inch, 17-Inch Mobile Workstation - Apple Devices Do Not Connect to the Computer
Release date : 26-Nov-2013
Last updated : 26-Nov-2013
DESCRIPTION
User may experience some functional loss when connecting Apple devices via Thunderbolt connections. Issues may range from unrecognized devices to device failure when system hibernates.
SCOPE
Computers:
  • HP ZBook 15-inch Mobile Workstation
  • HP ZBook 17-inch Mobile Workstation
RESOLUTION
Apple devices are not certified by Intel for use with a Windows-based PC. As such, HP does not support issues of decreased functionality when the user introduces Apple devices to the Thunderbolt connections.
The Apple Thunderbolt monitor will function as a display device when connected directly to the PC. Other connections may result in a faulty user experience.
Hardware platforms affected : HP ZBook 15 Mobile Workstation, HP ZBook 17 Mobile Workstation
Support Communication Cross Reference ID : IA04027033
Country/Region: Middle East
