Document ID: c04024957
Version: 1
HP ZBook 15-Inch and 17-Inch Mobile Workstation Notebook PCs - Black Screen Occurs on Internal Screen After Upgrading Microsoft Windows 8.1
Release date : 22-Nov-2013
Last updated : 25-Nov-2013
DESCRIPTION
The internal display is black except for the cursor which can be moved across the screen. The external monitors may also be black. This issue occurs after upgrading to Microsoft Windows 8.1 using an upgrade CD. This issue does not occur if the computer is upgraded using the online Microsoft Store upgrade..
SCOPE
Computers:
  • HP ZBook 15-inch Mobile Workstation
  • HP ZBook 17-inch Mobile Workstation
Operating Systems:
  • Microsoft Windows 8.1 (standard)
  • Microsoft Windows 8.1 Pro
RESOLUTION
To prevent this issue from occuring, complete the following steps before starting the Microsoft Window 8.1 upgrade:
  1. Download and save the appropriate graphics drivers on a disc or a USB drive.
  2. Perform the Windows 8.1 upgrade through the operating system CD.
    Do not connect to the internet while completing the upgrade.
  3. After the computer has finished upgrading, power on the computer, connect the USB drive or insert the CD and install the appropriate graphics drivers.
    SoftPaq Description
    Release Notes
    Download SoftPaq
    Intel Video Driver and Control Panel
    Version: 10.18.10.3308
    Revision: A
    NVIDIA Video Driver and Control Panel
    Version: 327.31
    A more recent version of this software may be available. Check for newer versions at http://www.hp.com/.
  4. Restart the computer and check the graphics driver.
  5. Connect to the internet to perform other necessary system updates.
If the issue has already occurred, complete the following procedure:
  1. Press the power button until the computer powers off.
  2. Power on the computer and immediately press F10 to enter BIOS.
  3. Select Advanced, then Device Configurations.
  4. Next to Hybrid Graphics change Auto to Disable.
  5. Select Save and Exit.
  6. Restart the computer.
  7. Check the internal display.
  8. Restart the computer and immediately press F10, select Advanced, then Device Configurations.
  9. Next to Hybrid Graphics change Disable to Auto.
  10. Select Save and Exit.
  11. Restart the computer.
Hardware platforms affected : HP ZBook 15 Mobile Workstation, HP ZBook 17 Mobile Workstation
Support Communication Cross Reference ID : IA04024957
Country/Region: Middle East
