This document is for HP Color LaserJet Pro M282nw, M283cdw, M283fdn, and M283fdw printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, load paper into the input tray, connect the power cable, set control panel preferences, and then download and install the printer software.
ملاحظة:If you are looking for the printer software, go to 123.hp.com.
