دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP Color LaserJet Pro MFP M282-M283 Printers - Replacing Toner Cartridges
This document is for HP Color LaserJet Pro M282nw, M283cdw, M283fdn, and M283fdw printers.
To replace the toner cartridge, open the toner cartridge door, remove the old toner cartridge, and then install the new toner cartridge.
ملاحظة:
The imaging drum is integrated into the toner cartridge. To replace the imaging drum, you must replace the toner cartridge.
Replace the toner cartridge
If a toner cartridge is empty, replace it with a new, genuine HP toner cartridge.
  1. Open the front door.
    Opening the front door
  2. Grasp the blue handle on the toner cartridge drawer, and thenpull out the drawer.
    Pulling out the cartridge drawer
  3. Grasp the handle on the toner cartridge, and then pull thetoner cartridge straight up to remove it.
    Removing the toner cartridge
  4. Remove the new toner cartridge package from the box, andthen pull the release tab on the packaging.
    Pulling the release tab
  5. Remove the toner cartridge.
      إنذار:
    Do not touch the imaging drum on the bottom of the tonercartridge. Fingerprints on the imaging drum can cause print qualityproblems.
    Removing the toner cartridge from the packaging
  6. Grasp both ends of the toner cartridge, and then gently rock the toner cartridge back and forth to distribute the toner.
    Gently rocking the toner cartridge back and forth
  7. Insert the new toner cartridge into the drawer. Make sure thatthe color chip on the cartridge matches the color chip on thedrawer.
    Inserting the toner cartridge
  8. Push the toner cartridge drawer into the printer.
    Pushing in toner cartridge drawer
  9. Close the front door.
    Closing the front door
Review the list of frequently asked questions about replacing the toner cartridges.
الدولة/المنطقة : العربية
