Load several envelopes in the main input tray or a single envelope in the priority feed slot.
Load envelopes in the main input tray to print addresses for the recipient and sender.
Pull out the input tray.
Open the paper cover.
Extend or shorten the input tray by pressing the latch and pulling out or pushing in the front of the tray, and then slide out the paper guides as far as possible.
Load envelopes into the input tray. To prevent paper jams, make sure the stack is below the paper fill guide.
Slide in the paper guides until they touch the edge of the stack of envelopes.
Close the paper cover, and then push in the input tray.
Lift the output support to open it.
ملاحظة:
Before printing or copying, select the correct tray, paper size, and paper type settings from the control panel or computer.
