دعم عملاء HP - قاعدة المعارف
HP OfficeJet Pro 8700 Printers - Replacing Ink Cartridges
This document is for HP OfficeJet Pro 8720, 8725, 8728, 8730, 8732M, 8740, 8745 All-in-One printers.
This document contains steps for replacing the ink cartridges.
Replace the ink cartridges
Replace any low or empty ink cartridges.
  1. Open the ink cartridge access door.
  2. Wait until the carriage stops moving before you continue.
  3. Remove the old ink cartridge, and then insert the new ink cartridge into its slot.
    Animation showing an ink cartridge replacement
  4. Close the ink cartridge access door.
Review the list of frequently asked questions about replacing the ink cartridges.
الدولة/المنطقة : العربية
