دعم عملاء HP - قاعدة المعارف
HP DeskJet 1110, 1200 Printers - Loading Paper, Envelopes, and Cards
This document is for HP DeskJet 1110, 1111, 1112, 1210, 1212, 1255, DeskJet Ink Advantage 1115, 1118, 1216, and 1275 printers.
Load U.S. letter, A4, legal size paper, envelopes, photo paper or index cards in the input tray. Make sure to place the printer on a hard, flat surface before you use it. Using the printer on an uneven or unsteady surface might cause the pages to print skewed, or might cause paper size adjustment issues.
  إنذار:
Do not load any media while the printer is printing. Jams or paper feed issues might occur.
الدولة/المنطقة : العربية
