دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP Products - Getting Started with Touch-to-Print
This document is for HP products that support NFC touch-to-print.
ملاحظة:
This document is no longer updated after September 2019.
Learn how to get started with NFC touch-to-print and begin using this new feature. NFC touch-to-print is a feature on select HP printers that lets you print wirelessly from mobile devices that support near field communication (NFC) and HP NFC printing standards.
All you need is an HP ElitePad 900 or an Android mobile device that supports NFC and an NFC-compatible HP printer.
Frequently asked questions related to setting up and using touch-to-print.
الدولة/المنطقة : العربية
