دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP OfficeJet 8600, 8702, Pro 8610/20/30/40/60, 8710 Printers - Replacing Ink Cartridges
This document is for the following printers.
HP OfficeJet 8600 Series Printer
HP Officejet Pro 8640 e-All-in-One Printer
HP Officejet Pro 8610 e-All-in-One Printer
HP Officejet Pro 8660 e-All-in-One Printer
HP Officejet Pro 8615 e-All-in-One Printer
HP OfficeJet 8702 All-in-One Printer
HP Officejet Pro 8616 e-All-in-One Printer
HP OfficeJet Pro 8710 All-in-One Printer
HP Officejet Pro 8620 e-All-in-One Printer
HP OfficeJet Pro 8715 All-in-One Printer
HP Officejet Pro 8625 e-All-in-One Printer
HP OfficeJet Pro 8717 All-in-One Printer
HP Officejet Pro 8630 e-All-in-One Printer
HP OfficeJet Pro 8718 All-in-One Printer
HP OfficeJet Pro 8719 All-in-One Printer
This document contains steps for replacing the cartridges.
Video of replacing an ink cartridge in the HP OfficeJet Pro 8710 Printers
Replace the cartridges
Follow these steps to replace the cartridges.
  1. Turn on the printer.
  2. Place your fingers into the slot on the left side of the printer, and then pull to open the cartridge access door.
    The carriage moves to the left side of the printer.
      Image: Open the cartridge access door.
    1. Slot for opening the cartridge access door
  3. Wait until the carriage is idle and silent.
  4. Push in on the front of the cartridge to release it, and then pull it toward you to remove it from its slot.
    Image: Remove the cartridge from its slot.
  5. Remove the new cartridge from its package.
  6. Hold the new cartridge so that the cartridge contacts face the printer.
  7. Slide the new ink cartridge into its slot, and then gently push it forward until it snaps into place. Make sure the letter on the ink cartridge matches the letter on the slot.
      إنذار:
    Do not lift the latch handle on the carriage to insert ink cartridges. Doing so could cause the printhead or ink cartridges to be incorrectlyseated, which could damage the print mechanism and cause printing problems.
    Image: Insert the ink cartridge into its color-coded slot
  8. Repeat these steps to install any other new cartridges.
  9. Close the cartridge access door.
    Image: Close the cartridge access door
الدولة/المنطقة : العربية
