دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
Setting Up the Printer Hardware for HP LaserJet Pro MFP M127fw and M128fw Printer Series
Setting up the printer
Follow these steps in order.
Step 1: Check the contents of the box
Step 2: Remove the packaging, and then prepare the printer
Follow these steps to remove all the packaging material from the printer, and then prepare the printer for use.
  1. Take the printer out of its box, and then remove the packaging.
  2. Place the printer in a sturdy, well-ventilated, and dust-free place away from direct sunlight.
  3. Remove the packing tape from the printer.
    الشكل : Remove the packing tape from the printer
    Image: Remove the packing tape from the printer.
  4. Open the scanner assembly, and then open the top cover.
    الشكل : Open the scanner assembly, and then open the top cover
    Image: Open the scanner assembly, and then open the top cover.
  5. Remove the protective foam from the cartridge access area.
    الشكل : Remove the protective foam
    Image:Remove the protective foam.
  6. Remove the print cartridge, and then set it down in a secure place.
    الشكل : Remove the print cartridge
    Image: Remove the print cartridge, and set it down in a secure place.
  7. Remove packaging from inside the printer.
    الشكل : Remove packaging from inside the printer
    Image: Remove packaging from inside the printer.
  8. Grasp both sides of the print cartridge, and then gently rock the cartridge to distribute the toner.
    الشكل : Gently rock the print cartridge
    Gently rock the print cartridge.
  9. Remove the orange clip from the print cartridge.
    الشكل : Remove the orange clip from the print cartridge
    Image: Remove the orange plastic clip from the print cartridge.
  10. Pull the orange tab to remove the sealing tape from the print cartridge.
    الشكل : Remove the sealing tape from the print cartridge
    Image: Pull the orange tab to remove the sealing tape from the print cartridge.
  11. Align the print cartridge with the tracks inside the printer, and then insert the print cartridge until it is firmly seated.
    الشكل : Insert the print cartridge
    Image: Insert the print cartridge.
  12. Close the top cover, and then close the scanner assembly.
  13. Attach the input paper tray to the printer.
    الشكل : Attach the input paper tray to the printer
    Image: Attach the  input paper tray to the printer.
Step 3: Load paper
Follow these steps to load paper in the paper input tray.
  1. Slide the paper guides to their outermost positions.
    الشكل : Slide the paper guides out
    Image: Slide the paper guides out
  2. Load a stack of U.S. letter or A4 size paper into the input tray with the short edge forward and the print side up. Push the stack into the tray until it stops.
    الشكل : Load paper into the input tray
    Image: Load paper into the input tray
  3. Slide in the paper guides until they rest against the edges of the paper.
    ملاحظة:
    Do not push the paper guides so far in that they bind the paper.
    الشكل : Slide the paper guides in
    Image: Slide the paper guides in.
Step 4: Connect the power cord, and then turn on the printer
  1. Connect the power cord to the rear of the printer.
  2. Plug the power cord directly into an electrical outlet.
    الشكل : Connect the power cord
    Image: Connect the power cord.
  3. Press the Power button to turn on the printer. The printer initializes and calibrates itself.
    ملاحظة:
    Wait until the printer is idle and silent before you proceed.
Step 5: Select the language and country
Follow these steps to select the language displayed on the printer control panel.
  1. On the printer control panel, touch your Language, if necessary, touch the Down Arrow () to find your language in the list.
  2. Select your Country/Region.
ملاحظة:
If you selected the wrong language, touch the Setup () icon on the home screen.
  • Touch the bottom option on the first page, (System Setup).
  • Select the top option of the page, (Language).
  • If necessary, touch the Down Arrow () to find your desired language in the list.
  • Touch your language, and then touch the top option to confirm your selection.
  • Touch the Home button () to return to the home screen.
Link to fax setup instructions
Set up the printer to send and receive faxes
الدولة/المنطقة : العربية
