دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP Printers - Creating Custom Paper Sizes
This document is for HP inkjet printers introduced after February 2013.
You can print to non-standard paper sizes with many types of HP home and small office printers. Print to any size paper within the minimum and maximum printing dimensions supported by your printer.
  إنذار:
To avoid print quality problems and other issues, make sure your custom size does not exceed the actual size of your paper.
الدولة/المنطقة : العربية
