This document is for HP Deskjet 1000, 2000, 3000, and Deskjet Ink Advantage 2010 printers.
To prevent print quality issues, replace the ink cartridges when they are low or out of ink.
Ink cartridge description
North America and Asia Pacific, including Japan (excluding India, China, and Indonesia)
Western Europe
Middle East, Africa, Latin America, and CIS
China, India, and Indonesia
Black ink cartridge
HP 61 Black
HP 301 Black
HP 122 Black
HP 802 Black
Color ink cartridge
HP 61 Tri-color
HP 301 Tri-color
HP 122 Tri-color
HP 802 Tri-color
The Americas
Europe
Middle East and Africa
Asia Pacific
Black ink cartridge
HP 704 Black
N/A
N/A
HP 704 Black
Color ink cartridge
HP 704 Tri-Color
N/A
N/A
HP 704 Tri-Color
ملاحظة:The video shows the HP Deskjet 3000. The outside of the product might not look the same as your product, but the steps are the same.
إنذار:Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. Also, do not re-tape the cartridges. Doing so can result in clogs, ink failure, and bad electrical connections.الشكل : Do not touch electrical contacts or ink nozzles![]()
