This document describes how to set up the product hardware and install the software.
- ${title}
دعم عملاء HP - قاعدة المعارف
- ${title}
- ${title}
- ${title}
HP Deskjet D5560 and D5568 Printers - Setting up a New Printer
Setting up a new printer
Follow these steps to set up the product hardware and install the software.
إنذار:Do not connect the USB cable until these steps prompt you to do so.
Step one: Verify the box contents
Make sure the box contains the following items along with the new HP product:
Item
Example
Cartridges
Software CD
USB cable
Power cord
Power supply
Step two: Unpack the printer
Lift the product out of its box.
Remove all tape from the paper tray, and then open the cartridge door.الشكل : Open the cartridge door
Remove the packing material from inside the front access door.
Close the cartridge door.الشكل : Close the cartridge door
Step three: Connect the power
إنذار:Do not connect the USB cable at this stage.
الشكل : Do not connect the USB cable yet
Turn the product to access its rear side.
Plug the power cord into the rear of the product.الشكل : Connect the power cord to the rear of the product
Connect the power cord to the power supply.الشكل : Connect the power cord to the power supply
Plug the other end of the power cord into an electrical outlet.الشكل : Connect the power cord to the electrical outlet
Press the Power button (
) to turn on the product.
Step four: Load plain paper
Open the paper tray.الشكل : Open the input paper tray
Pull out the paper tray extender.الشكل : Pull out the paper tray extender
Lift up the paper stop at the end of the paper tray extender.الشكل : Lift up the paper stop
Slide the paper-width guide to its outermost position.الشكل : Slide the paper guide out
Load the stack of paper into the paper tray with the short edge forward and the print side down. Slide the paper under the output platform, and push it forward until it stops.الشكل : Load paper
Slide the paper guide inward until it rests against the paper.الشكل : Slide the paper guide inward
Step five: Install the cartridges
Open the cartridge door.الشكل : Open the cartridge door
Wait until the carriage moves to the center of the product and is idle and silent.
Remove one of the new cartridges from its packaging, and then pull the pink pull-tab to remove the protective tape from the nozzles.الشكل : Remove the protective tape
إنذار:
Do not touch the cartridge contacts or ink nozzlesالشكل : Do not touch the contacts -
Hold the cartridge by its sides.الشكل : Hold the cartridge by its sides
Insert the cartridge into its designated slot. The black parallelogram icon (
) designates the slot for the black cartridge, and the magenta half circle icon (
) designates the slot for the color cartridge.
الشكل : Insert cartridgeالشكل : Cartridge rests at upward angle -
Press the cartridge in to snap it into place.الشكل : Snap cartridge into place
Repeat these steps to replace the other cartridge.
Close the cartridge door.الشكل : Close the cartridge doorWhen you close the cartridge door, a cartridge alignment process begins automatically within 90 seconds.
If the alignment process does begin automatically, skip the next step, and continue to the following step to install the software.
If the alignment process does not begin automatically, continue to the next step to align the cartridges manually.
Step six: Align the cartridges
Open HP Solution Center using one of the following methods.
Windows Vista: On the Windows taskbar, click the Windows icon (
), click All Programs, point to HP, and then click HP Solution Center.
Windows XP: On the Windows taskbar, click Start, click All Programs, point to HP, and then click HP Solution Center.
Click Settings, and then click Printer Toolbox. The Printer Toolbox dialog box opens.
Click Align the Print Cartridges.
Click Align, and then follow the on-screen instructions.The product prints a test page, aligns the ink cartridges, and calibrates the product.
Step seven: Install the software
Use one of the following options to install the software.
ملاحظة:If you do not have the software CD, see Option three at the end of this section to download and install the software.
Option one: Install the software from the CD on a Windows computer
Insert the software CD into the CD drive of the computer.
إنذار:
Do not connect the USB cable yet.الشكل : Insert the software CD, but do not connect the USB cable -
Follow the on-screen instructions until the software prompts you to connect the USB cable.الشكل : Windows on-screen installation instructions
When prompted, connect the USB cable to the rear of the product and to the computer.الشكل : Connect the USB cable
Continue to follow the on-screen instructions to complete the installation.
Option two: Install the software from a CD on a Macintosh computer
Connect the USB cable to the rear of the product and to the computer.الشكل : Connect the USB cable
Insert the CD into the CD drive on the computer.الشكل : Insert the CD
Follow the on-screen instructions to complete the installation.الشكل : Macintosh on-screen installation instructions
خيارات دعم إضافية
- ${title}
- ${title}
- ${title}
الدولة/المنطقة :
العربية
- ${title}
hp-hero-support-search
- ${title}
