دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP LaserJet M1319f Multifunction Printer - Setting Up a New Multifunction Printer
This document explains the basics of setting up and configuring the printer hardware.
Setting up a new multifunction printer
Follow these steps to set up the hardware for your new product.
Step one: Unpack the multifunction printer
  1. Unpack the product.
    الشكل : Unpack the product
    Unpacking the items that shipped with the product
  2. Remove all the orange shipping tape and packaging material from the product.
    الشكل : Remove all orange tape
    Remove orange tape from the inside and outside of the printer
Step two: Attach the control panel faceplate and paper supports
  1. Install the control panel faceplate.
    الشكل : Install the control panel faceplate
    Attach the faceplate
  2. Install the automatic document feeder (ADF) input tray.
    الشكل : The ADF input tray
    Install the ADF input tray
  3. Install the ADF output support.
    الشكل : The ADF output support
  4. Install the paper tray.
    الشكل : Install the paper tray
  5. Install the paper support.
    الشكل : The paper support
Step three: Load plain paper
  1. Adjust the paper guides to match the width of the paper you are loading.
    الشكل : Adjust the paper guide
  2. Load paper with the top forward and the side to be printed on facing down.
    الشكل : Load paper
    Load paper
Step four: Install the print cartridge
  1. Open the print cartridge door.
    الشكل : Open the print cartridge door
  2. Remove the new print cartridge from its packaging and rock the cartridge multiple times to ensure uniform printing. Remove the orange cover, and then pull the orange tab straight out to remove the sealing tape.
    الشكل : Remove the new print cartridge from packaging
    Rock the cartridge and remove all orange tabs
  3. Insert the cartridge into the product until it is firmly in place.
    الشكل : Insert the cartridge
  4. Close the print cartridge door.
    الشكل : Close the cartridge door
Step five: Connect the handset, phone, and power cables
  1. Connect the handset to the back of the product.
    الشكل : Connect the handset
    Connect the handset to the top jack
  2. Connect the phone cord for the fax line to the back of the product.
    الشكل : Connect the phone cord
    Connect the phone cord in the bottom jack
  3. Connect the power cord to the back of the product and into an electrical outlet.
    الشكل : Connect the power cord
    Attach the power cord to the back of the product
  4. Turn on the power using the power switch on the back of the product.
    الشكل : Turn on power
    Turn on the power switch above the power cord
Step six: Select the language/region
Follow the instructions on the control panel to set the default language and location. The product automatically restarts after selecting the location.
You have completed the hardware portion of your product setup.
If you are using this product as a stand-alone fax, skip to the 'Configuring your product' section of this document.
If you did not complete a recommended install on your computer, you will need to manually set the time, date, and fax header.
Setting the time and date
  1. Press the Setup () button.
  2. Use the arrow buttons ( or ) to select System setup, and then press OK.
  3. Use the arrow buttons ( or ) to select Time/Date, and then press OK.
  4. Use the arrow buttons ( or ) to select the 12-hour or 24-hour clock, and then press OK.
  5. Use the alphanumeric buttons to enter the current time.
  6. Confirm the time.
    • For the 12-hour clock, use the arrow buttons ( or ) to move past the fourth character. Select 1 for a.m. and 2 for p.m., and then press OK.
    • For the 24 hour clock, press OK.
  7. Use the arrow buttons ( or ) to select the date format, and then press OK.
  8. Use the alphanumeric buttons to enter the current date. Use two digits to specify the month, day, and year, and then press OK.
Setting the fax header
  2. Use the arrow buttons ( or ) to select Fax setup, and then press OK.
  3. Use the arrow buttons ( or ) to select Fax header, and then press OK.
  4. Use the alphanumberic buttons to enter the fax number and a company name or header, and then press OK.
    ملاحظة:
    The maximum number of characters for the fax number is 20; use up to 25 characters for the company name.
Printing a self test page
To review current settings, print a self test page from the control panel.
  2. Use the arrow buttons ( or ) to select Reports, select Config report, and then press OK.
    A self test page prints.
الدولة/المنطقة : العربية
