دعم عملاء HP - قاعدة المعارف
  • ردود الفعل
HP Photosmart 8150 Series Printers - Removing and Installing Print Cartridges
Cartridge replacement animation
Click the play button above () to see an animation on how to replace print cartridges, or continue to the sections below for detailed instructions.
Step one: Open the printer
  1. Make sure the printer is turned on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge cradle is idle and silent.
Step 2 - Remove old cartridges
  1. Press down lightly on top of the cartridge latch.
  2. Pull out the bottom of the latch to unhook it.
  3. Slide the cartridge out.
    الشكل : Open the cartridge latch
    الشكل : Slide the cartridge out
Step 3 - Use a cartridge protector
If you are temporarily removing a working cartridge (for instance, removing a Black cartridge in order to install a Photo cartridge), put it in a cartridge protector. Cartridge protectors come with Photo cartridges.
الشكل : Insert a cartridge into a cartridge protector
الشكل : To remove, press down on the latch
Step 4 - Make sure the new cartridges are compatible
Step 5 - Install the new cartridges
  1. If you are installing a new print cartridge, remove the protective tape.
      إنذار:
    Do not attempt to remove the copper strip.
    الشكل : Remove the protective tape
      إنذار:
    After the tape is removed, do not touch the copper contacts or the ink nozzles.
      الشكل : Contacts and nozzles
    1. Contacts
    2. Nozzles
  2. Hold the print cartridge so the nozzles are down and the contacts face toward the printer, then slide the cartridge into the carriage.
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
    الشكل : Put each cartridge into the proper slot
  3. Push down on the print cartridge latch until it snaps closed.
    الشكل : Slide the print cartridge in
    الشكل : Close the latch
  4. Close the printer cover.
الدولة/المنطقة : العربية
