دعم عملاء HP - قاعدة المعارف
HP PSC 1310 Series - Installing Cartridges
ملاحظة:
Install the cartridges as soon as possible after you remove the tape. Remove only the tape! Do not attempt to remove the copper strip.
الشكل : If you have a new print cartridge, remove the tape
الشكل : Make sure the printer is turned on
الشكل : Open both doors on the printer, then wait a moment for the cartridge carriage to come to the center
الشكل : Place the tri-color cartridge in the left slot at a slight angle, then press up and forward until the cartridge snaps into position
الشكل : Place the black or photo cartridge in the right slot at a slight angle, then press up and forward until the cartridge snaps into position
الشكل : Close the gray door
الدولة/المنطقة : العربية
