- ${title}
دعم عملاء HP - قاعدة المعارف
- ${title}
- ${title}
- ${title}
HP Deskjet 5000 Series Printers - Setting Up the Product (Hardware)
Set up the product
Follow these steps in order.
Step one: Check the contents of the box
الشكل : Product and peripherals
Step two: Remove packing material
Remove all tape and protective film from the lid and from the front and back of the product.
Step three: Install the optional Two Sided Printing Accessory (duplexer)
If the product shipped with the Two Sided Printing Accessory (duplexer), continue with the following steps.
If the product did not ship with the duplexer, skip to the 'Connect the power cord and adapter' section in this document.
Press the two release buttons in the middle of the product on the rear access door, and then remove the door.الشكل : Remove the rear access door
Insert the duplexer into the back of the printer.الشكل : Insert the duplexer
Step four: Connect the power cord and turn the product on
Insert the rectangular end of the power cord into the power outlet on the back of the product.
Insert the other end of the cord into an electrical outlet.الشكل : Connect the power supply
Press the Power button (
) to turn on the product.
Step five: Load paper
Slide the paper adjuster out as far as it will go.
Push up the OUT tray.الشكل : Push up the OUT tray
Load a small stack of paper into the IN tray.
Slide the paper adjusters snugly against the edges of the paper.
Push the OUT tray down.
Step six: Install the cartridges
Follow these steps to install the cartridges.
Step
Example
الشكل : Open the product and remove the old cartridge
Remove a new cartridge from its packaging, and then carefully remove the plastic tape. Hold the cartridge so that the copper strip is on the bottom.
إنذار: |
الشكل : Remove the protective tape
الشكل : Insert the new cartridge
خيارات دعم إضافية
- ${title}
- ${title}
- ${title}
الدولة/المنطقة :
العربية
- ${title}
hp-hero-support-search
- ${title}
