1U9S9EA
HP Laptop - 15s-eq1023nh
AMD Ryzen™ 3 3250U (2.6 GHz base clock, up to 3.5 GHz max boost clock, 1 MB L2 cache, 2 cores)
AMD Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
AMD Radeon™ Graphics
128 GB PCIe® NVMe™ M.2 SSD
Optical drive
Optical drive not included
39.6 cm (15.6") diagonal, FHD (1920 x 1080), micro-edge, anti-glare, 220 nits, 45% NTSC
Realtek 802.11 b/g/n/ac (2x2) and Bluetooth® 5 combo
35.85 x 24.2 x 1.79 cm
1.69 kg
45 W Smart AC power adapter
3-cell, 41 Wh Li-ion
Battery life mixed usage
Up to 7 hours
Video Playback Battery life
Up to 8 hours and 30 minutes
HP TrueVision HD Camera with integrated dual array digital microphone
Dual speakers
- ${title}
- ${title}
- ${title}
- ${title}
HP Laptop - 15s-eq1023nh Product Specifications
Pre-installed software
ExpressVPN (30 day free trial)
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Estonia
- ${title}
hp-hero-support-search
- ${title}
