    Fix HP Printer issue on macOS
    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP Color LaserJet Pro M452 - Clear paper jams in Tray 1
When a jam occurs, the control panel displays an error message (2-line control panels) or an animation (touchscreen control panels) that assists in clearing the jam.
If the sheet tears, remove all fragments before resuming printing.
  1. If you can see the jammed sheet in Tray 1, remove the jammed sheet by pulling it straight out.
    Figure : Remove jammed paper
  2. If you cannot see the jammed sheet, close Tray 1, and then remove Tray 2.
    Figure : Remove Tray 2
  3. At the left side of the Tray 2 cavity, press the tab to lower the tray plate, and then remove any paper. Remove the jammed sheet by gently pulling it straight out.
    Figure : Remove the jammed paper
  4. Push the tray plate back up into place.
    Figure : Set the tray plate back in place
  5. Reinstall Tray 2.
    Figure : Reinstall Tray 2
  6. Reopen Tray 1 and load paper into the tray.
    Figure : Reload paper in Tray 1
Country/Region: Flag Estonia
