HP x23LED 23-inch WLED Backlit LCD Monitor - Specifications
Physical specifications
Specification
Dimensions (H x W x D)
Unpacked w/stand
  • 40.78 x 56.93 x 18.59 cm (16.06 x 22.41 x 7.32 in)
Unpacked w/o stand (head only)
  • 35.85 x 56.93 x 3.87 cm (14.11 x 22.41 x 1.52 in)
Packaged
  • 45 x 65.10 x 11.70 cm (17.72 x 25.63 x 4.61 in)
Head only
  • 3 kg (6.62 lb)
Unpacked
  • 3.3 kg (7.28 lb)
Packaged
  • 5.4 kg (11.90 lb)
Tilt range
-5° to +20°
Swivel range
No
Height adjustable
No
Pivot rotation
No
Base
Attachable, ships detached
Panel specifications
Specification
Type
23-inch Wide-Aspect Active Matrix TFT (thin film transistor)
58.42 cm (23 in) widescreen
Screen opening (W x H)
50.92 x 28.64 cm (20.05 x 11.28 in)
Panel type
TN with white LED backlight
Resolution
1920 X 1080 @ 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 170° horizontal/160° vertical (10:1 minimum contrast ratio)
Brightness (typical)1
250 nits (cd/m2)
Contrast ratio (typical)1
1,000:1
Dynamic contrast ratio (typical)1
1 Milion:1
Response time (typical)1
5 ms (On/Off)
Pixel pitch
0.02652 cm
Backlight lamp life (to half brightness)
30,000 hours
Color gamut
68%
1: All performance specifications represent the typical specifications provided by HP's component manufacturers; actual performance may vary either higher or lower.
On Screen Display (OSD) controls specifications
Specification
Buttons or switches
Power, Menu, "+", "-", Auto
Languages
English, Spanish, French, Portuguese, Russian, Simplified Chinese, Traditional Chinese, Korean
User controls
Brightness, contrast, positioning, color temperature (normal, warm, cool, sRGB and user), input select, clock, clock phase, DCR On/Off, DDC/CI On/Off, language selection and reset.
Signal interface/performance specifications
Specification
Horizontal frequency
50 to 75 kHz
Vertical frequency
24 to 83 Hz
Native resolution
1920 x 1080 @ 60 Hz
Preset VESA graphic modes (non-interlaced)
  • 640 x 480 @ 60Hz
  • 720 x 400 @ 70 Hz
  • 800 x 600 @ 60 Hz
  • 1024 x 768 @ 60 Hz
  • 1280 x 720 @ 60 Hz
  • 1280 X 960 @ 60 Hz
  • 1280 x 1024 @ 60 Hz
  • 1600 x 900 @ 60 Hz
  • 1600 x 1200 @ 60 Hz (scaled down vertically)
  • 1680 x 1050 @ 60 Hz
  • 1920 x 1080 @ 60 Hz
Text mode
720 x 400 @ 70 Hz
Maximum pixel clock speed
170 MHz
User programmable modes
Yes (11)
Anti-glare
No
Anti-static
No
Default color temperature
Warm (6500 K)
Video/other inputs specifications
Specification
Plug and play
Yes
Input connectors
VGA (analog), DVI-D w/HDCP
Input impedance
75 Ohms
Sync input
TTL separate synch
Video cable
One DVI-D to DVI-D
Video cable lengths
180 cm (5.9 ft)
Power specifications
Specification
Input power
90 to 230 V ac, 50 or 60 Hz
Typical power consumption
28 W
Maximum
30 W
Power saving
< 1 W
Power cable length
180 cm (5.9 ft)
Environmental specifications
Specification
Operating temperature
0° to 40°C (32° to 104°F)
Non-operating temperature
-20° to 60°C (-4° to 140°F)
Operating humidity
20% to 80% non-condensing
Non-operating humidity
5% to 90%
Operating altitude
+0 to 3,658 m (12,000 ft)
Non-operating altitude
+0 to 12,192 m (40,000 ft)
Country/Region: Flag Estonia
