This document pertains to HP LaserJet M232e-M237e printers using HP Smart in Windows or MacOS.
Setup your new HP+ printer using HP Smart.
bemærk:To set up and use the printer, it must always be connected to the internet.
bemærk:If you are installing HP Smart for the first time, the Sign in and Skip for now options are also displayed. Refer to What are the Sign in and Skip for now options? in the Frequently Asked Questions section for more information.
bemærk:Make sure to enter your network password if prompted.
bemærk:If the Firmware Uploading error displays, click Exit setup, and then click Finish Setup to restart the firmware update.
